LinkIt ONE Display Only 4 Wires
1,996
23
17
Posted
Introduction: LinkIt ONE Display Only 4 Wires
The LinkIt One board is a lot like an Arduino but with 10 times the power. Many projects require some sort of way to communicate to the world. A great way of doing this is with a 16x2 LCD Display. Great!
But there is a drawback. These displays will consume more than half the pins on an Arduino Uno leaving no room for your project to connect to the world!
Not any more! You can attach what's called an I2C backpack to your display and tap into the I2C protocol. This uses only 4 wires including power and ground!
The LinkIt ONE board supports I2C and is great for developing projects that require lots of ways to communicate. This project is a base for any project needing to communicate with the least amount of wires possible. Let's get started!
Materials
LinkIt ONE Developement Board
I2C Display
Let's get started!
Step 1: Software
Assuming you have your board setup you will only need the library I attached below. This library takes care of setting up the I2C part of the screen and is based on the original Liquid Crystal Display library.
Download it, extract it, and stick it in your Arduino library folder. Now, there is one thing you must note. The address of your screen may be different from the address in the example. See the picture above. The default is 0x27 but change this to what your vendor says the address is. If your having problems comment and I will help you.
Now, re-open the Arduino IDE and go to File>Examples>LiquidCrystal_I2C>Hello World. Once this opens proceed to the next step.
Step 2: Wiring
Like I said, wiring is very simple! All you need to do is attach the following:
LCD --------- Board
SDA --------- SDA
SCL --------- SCL
VCC --------- VCC
GND --------- GND
The picture above shows it all. Make sure to check, double check, and triple check your power wires. If you accidentally connect power to ground and ground to power you won't see hello world; you will smell goodbye world!
Sarcasm aside, do be careful because I fried an LCD doing that.
Step 3: Results
Now that you've got it wired right, plug in the board and select the port from Tools>Port. Now, upload the code! You should be greeted by the board!
This instructable was aimed at begginners so feel free to ask all your questions! I usually get back fairly quickly!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    6 Comments
    Ran the i2c finder.... Told me the address for my device was every single address possible
    This woks when compiled and run on an arduino but does not work for the linkit one.... Gives me a crap load of errors:
    Arduino: 1.6.5 (Windows 8.1), Board: "LinkIt ONE"
    Build options changed, rebuilding all
    In file included from C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:35:0:
    C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp: In member function 'uint8_t LiquidCrystal_SR1W::clearSR()':
    C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:77:24: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
    SR1W_ATOMIC_WRITE_LOW(srRegister, srMask);
    C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.h:293:79: note: in definition of macro 'SR1W_ATOMIC_WRITE_LOW'
    #define SR1W_ATOMIC_WRITE_LOW(reg, mask) ATOMIC_BLOCK(ATOMIC_RESTORESTATE) { *reg &= ~mask; }
    C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:86:22: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
    fio_bit reg_val = *srRegister;
    C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:95:5: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
    *srRegister = bit_high;
    C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:96:5: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
    *srRegister = bit_low;
    C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:101:4: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
    C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp: In member function 'uint8_t LiquidCrystal_SR1W::loadSR(uint8_t)':
    C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:139:24: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
    C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:144:6: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
    C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:145:6: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
    C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:151:26: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
    C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:158:27: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
    SR1W_ATOMIC_WRITE_HIGH(srRegister, srMask);
    C:\Program Files (x86)\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.h:294:80: note: in definition of macro 'SR1W_ATOMIC_WRITE_HIGH'
    #define SR1W_ATOMIC_WRITE_HIGH(reg, mask) ATOMIC_BLOCK(ATOMIC_RESTORESTATE) { *reg |= mask; }
    Error compiling.
    I have wired it correctly I can say that much for sure. Address is supposed to be 0x27 and yes it is i2c compatible as it has that adapter board like yours does. I bought it from this location:
    https://www.fasttech.com/products/0/10004916/1380909-arduino-compatible-iic-i2c-serial-2-5-lcd-1602
    Tried this and all that happens is my LCD flashes on and off again and then nothing...
    Ya corregí el error anterior, pero no me muestra nada en lCD
    Tengo un error, al tratar de cargar un programa es el siguiente:
    Arduino: 1.5.7 (Windows 7), Board: "LinkIt ONE"
    C:\Users\Documents\Arduino\libraries\LiquidCrystal\LiquidCrystal.cpp: In member function 'virtual void LiquidCrystal::setBacklight(uint8_t)':
    C:\Users\Documents\Arduino\libraries\LiquidCrystal\LiquidCrystal.cpp:173:41: error: 'digitalPinToTimer' was not declared in this scope
    if(digitalPinToTimer(_backlightPin) != NOT_ON_TIMER)
    C:\Users\Documents\Arduino\libraries\LiquidCrystal\LiquidCrystal.cpp:173:46: error: 'NOT_ON_TIMER' was not declared in this scope
    This report would have more information with
    "Show verbose output during compilation"
    enabled in File > Preferences.
