LinkIt One + Blynk LED Controller
Published
Introduction: LinkIt One + Blynk LED Controller
About: I like to create new things! I'm very interested in IOT and just Internet Stuff. I am not responsible for any injury or deaths caused by my projects.
Welcome to this linkit one tutorial!! I'm exited about this project and the ones to come!! In this instructable I will be showing how to control a led from anywhere with blynk. If you haven't set up your linkit board check out my other project here.
Step 1: Program
Once again click here if you don't know how to program your board.
Install the blynk library too, here is the link
Here is the code I made. WARNING: THE BLYNK EXAMPLE CODE DOESNT WORK!!
___________________________________________________________________________________
//This code has been edited by funguypro and tested wth the linkit one board// This sample verified with the Blynk 3.1 and iphone. checked with Analog A0, Virtual V0
#defineARDUINO150// to avoid Blynk library use yield() in function run(), without this. system will crash!
#include<LWiFi.h>
#include<LWiFiClient.h>
#include<BlynkSimpleLinkItONE.h>
// You should get Auth Token in the Blynk App.// Go to the Project Settings (nut icon).charauth[]="yourauthcode";
#defineWIFI_SSID"YOURSSIDHERE"// Your network SSID (name)#defineWIFI_PASS"YOURPASSHERE"// Your network password (use for WPA, or use as key for WEP)#defineWIFI_AUTHLWIFI_WPA// choose from LWIFI_OPEN, LWIFI_WPA, or LWIFI_WEP
voidsetup(){
Serial.begin(9600);
Blynk.begin(auth,WIFI_SSID,WIFI_PASS,WIFI_AUTH);
Serial.println("System start!");
uint16_tloop_id=0;
voidloop(){
loop_id++;
Serial.println(loop_id);
Blynk.run();
BLYNK_READ(0){
Serial.println("Blynk comes to read!");
Blynk.virtualWrite(0,loop_id);
/p>
Step 2: Connect Led and Test
I hope you enjoyed this project!! Stay tuned for more Linkit One Projects
Step 3: Questions?
Feel free to contact me! http://goo.gl/forms/wsFpmA7SOH
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    2 Discussions
    Thanks! I was looking for just this tutorial :) The only difference I made was to set the button to D13 in the Blynk app, that way I didn't need to set up an external LED, how lazy was I? ;)
