Introduction: Linking Cards
This will teach you how to magically link 2 ordinary playing cards.
Step 1: The Set Up
Make a small rip on the side of 1 of the playing cards.
Step 2: Rip Out the Center
Then fold the card in half and rip out the center.
(This gives you 1 card with a hole in it and 1 with a rip in the side and a hole in it.) see pictures.
Step 3: Finish
Now while covering the rip in the side of 1 of the boxes bring them together. let the 2 slide together and then with a sharp movement pull them apart and let go of the one that is not ripped so that it hangs in space.
Then "rip" apart one card to separate them. What you acutely do is pull apart at the existing break. Throw every thing out for inspection and watch as the praise comes in.
Note: also you can do this with business cards!
14 Comments
THANKS, IT'S A VERY MYSTIFYING TRICK.
Actually there is a much more astonishing way to link two cards. A trick called conjunction which is in the paul harris true astonishment dvds
Its a bit obvious...Adn by I bit i mean totally obvious...
what you can also do is before the act take 2 cards from another deck, rip them into rings and rip one ring as clean as possible, link the rings and use a little amount of superglue to put the ring back together, then do the trick as described above with two forced cards (the same ones as those you already linked), switch the links and give the unbroken ring to the audience
me neather
I Didn't Really get that trick
Oh My Christ!
french crawler, nice idea il have to try that, thanks!=)
you're welcome
What you should do, is have an extra Jack of Hearts without the rip palmed in one hand and when you tear them apart do the switch. Then you can pocket (usually the back pocket) the ripped one and let the spectator(s) examine the unripped cards. At least that's what I'd do.
