Linkit ONE Music Player
2,709
47
Published
Introduction: Linkit ONE Music Player
This instructable will guide you to play and MP3 file on linkit one through a micro SD card. This projects makes use of the Audio jack and SD card reader features of the Mediatek Linkit ONE board.
So let's begin...
Step 1: Requirements
You will require the following parts:
  • Linkit one
  • Linkit one battery
  • Memory card with songs loaded
  • Speaker or earphones
That's it!
Step 2: Insert Memory Card and Connect Battery
Insert your memory card in the SIM/ Micro SD combo linkit one. Your SD card should be formatted first and then songs should be loaded.
Then connect the lithium battery to the socket present on linkit one.
Step 3: Upload Code
Upload this code to your linkit one with the switches in SPI and UART positions. Change the "define" line with the file name you want to play.
#include <LSD.h>
#include <LAudio.h> #define file_name (char *)"xyz.mp3" // change this to the song you want to play
void play(char * filename) { LAudio.setVolume(5); LAudio.playFile(storageSD, filename); Serial.print("Playing: "); Serial.println(filename); delay(5000); }
void setup() { Serial.begin(9600); while (!Serial); Serial.println("Initializing SD Card..."); LSD.begin(); Serial.println("Card Initialized!"); }
void loop() { play(file_name); }
Step 4: Connect Speakers or Earphones and Play It!
Now connect your speakers of earphones to the 3.5mm audio jack on linkit one. Set the switches to MS, SD and BAT positions.
You will now be able to hear the song which you mentioned in the code
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
