Linkit One: Blowing an LED
Published
Introduction: Linkit One: Blowing an LED
In this tutorial I Will show you how to turn on an led with your mouth. The Led will turn on when start to blow the sound sensor
Step 1: Material and Setup
Material needed for this project are:
  1. Linkit One Board
  2. an LED
  3. digital sound sensor
  4. 3 male to female jumper cable
  5. micro USB cable
To setup the linkit one board follow this link
the connection between the sensor and linkit one board:
sensor linkit one
5v<------------>5v
GND <-------> GND
Out <---------> D2
Step 2: The Code
Upload this code to your linkit one board. This is actually the digital pull up example from the arduino ide
Input Pullup Serial
This example demonstrates the use of pinMode(INPUT_PULLUP). It reads a digital input on pin 2 and prints the results to the serial monitor.
The circuit: * Momentary switch attached from pin 2 to ground * Built-in LED on pin 13
Unlike pinMode(INPUT), there is no pull-down resistor necessary. An internal 20K-ohm resistor is pulled to 5V. This configuration causes the input to read HIGH when the switch is open, and LOW when it is closed.
created 14 March 2012 by Scott Fitzgerald
http://www.arduino.cc/en/Tutorial/InputPullupSerial
This example code is in the public domain
void setup() { //start serial connection Serial.begin(9600); //configure pin2 as an input and enable the internal pull-up resistor pinMode(2, INPUT_PULLUP); pinMode(13, OUTPUT);
void loop() { //read the pushbutton value into a variable int sensorVal = digitalRead(2); //print out the value of the pushbutton Serial.println(sensorVal);
// Keep in mind the pullup means the pushbutton's // logic is inverted. It goes HIGH when it's open, // and LOW when it's pressed. Turn on pin 13 when the // button's pressed, and off when it's not: if (sensorVal == HIGH) { digitalWrite(13, LOW); } else { digitalWrite(13, HIGH); } }
Step 3: Test It Out
After you upload the code. open serial monitor then when you blow the sound sensor you will see the LED will also turn on.
The longer you blow, the longer the LED will turn on
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
