Linkit One Kitchen Timer
Published
Introduction: Linkit One Kitchen Timer
About: Hi, I just launched an Indigogo campaign support my projects by backing it. https://www.indiegogo.com/projects/tinker-usb-a-wifi-based-badusb#/
In this instructable I'm going to show you how to design a kitchen timer using the Linkit One, the timer has a maximum duration of 30 minutes. And once the timer is done counting down it fires a buzzer to notify you. The time interval can be set in steps of 5 minutes and each led indicating 5 minutes. You can also increase the maximum duration by adding extra LEDs and go up to a maximum of 50 minutes due to the limited number of pins on the Linkit one.
Step 1: Tools and Components
All the components you require for this instructable are -
  • Linkit One
  • 6 Leds
  • Push Button
  • Buzzer
  • Jumper wires
  • Breadboard
  • 10k resistor
Step 2: Circuit
The circuit is quite simple and all you need to do is follow the picture above. There are six LEDs and each LED indicates a 5 minute interval. By adding additional LEDs to the remaining digital pins you can improve the maximum duration of the timer circuit.
Step 3: Code
Copy the below code and paste the below code in the Arduino IDE and then select a suitable COM port and upload the code to the Linkit One.
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin const int led2Pin = 12; const int led3Pin = 11; const int led4Pin = 10; // the number of the LED pin const int led5Pin = 9; const int led6Pin = 7; const int led7Pin = 6; // the number of the LED pin const int led8Pin = 5; const int led9Pin = 4; const int led10Pin = 3; const int speakerOut = 1;
// variables will change: int buttonState = 0; // variable for reading the pushbutton status int tastyTimeVariable = 0; // my time variable that has 1 added int i; int n;
void setup() { // initialize the LED pin as an output: pinMode(ledPin, OUTPUT); pinMode(led2Pin, OUTPUT); pinMode(led3Pin, OUTPUT); pinMode(led4Pin, OUTPUT); pinMode(led5Pin, OUTPUT); pinMode(led6Pin, OUTPUT); pinMode(led7Pin, OUTPUT); pinMode(led8Pin, OUTPUT); pinMode(led9Pin, OUTPUT); pinMode(led10Pin, OUTPUT); // initialize the pushbutton pin as an input: pinMode(buttonPin, INPUT); pinMode(speakerOut, OUTPUT);
delay(3000); }
void loop(){ // read the state of the pushbutton value: buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed. // if it is, the buttonState is HIGH: if (buttonState == HIGH) { // add to timer tastyTimeVariable = tastyTimeVariable + 1; digitalWrite(ledPin, HIGH); } else { } delay(1000); buttonState = digitalRead(buttonPin); if (buttonState == HIGH) { // add to timer tastyTimeVariable = tastyTimeVariable + 1; digitalWrite(led2Pin, HIGH); } else { }
delay(1000);
buttonState = digitalRead(buttonPin); if (buttonState == HIGH) { // add to timer tastyTimeVariable = tastyTimeVariable + 1; digitalWrite(led3Pin, HIGH); } else { } delay(1000); buttonState = digitalRead(buttonPin); if (buttonState == HIGH) { // add to timer tastyTimeVariable = tastyTimeVariable + 1; digitalWrite(led4Pin, HIGH); } else { } delay(1000); buttonState = digitalRead(buttonPin); if (buttonState == HIGH) { // add to timer tastyTimeVariable = tastyTimeVariable + 1; digitalWrite(led5Pin, HIGH); } else { } delay(1000); buttonState = digitalRead(buttonPin); if (buttonState == HIGH) { // add to timer tastyTimeVariable = tastyTimeVariable + 1; digitalWrite(led6Pin, HIGH); } else { } delay(1000); buttonState = digitalRead(buttonPin); if (buttonState == HIGH) { // add to timer tastyTimeVariable = tastyTimeVariable + 1; digitalWrite(led7Pin, HIGH); } else { } delay(1000); buttonState = digitalRead(buttonPin); if (buttonState == HIGH) { // add to timer tastyTimeVariable = tastyTimeVariable + 1; digitalWrite(led8Pin, HIGH); } else { }
delay(1000);
buttonState = digitalRead(buttonPin); if (buttonState == HIGH) { // add to timer tastyTimeVariable = tastyTimeVariable + 1; digitalWrite(led9Pin, HIGH); } else { }
delay(1000);
buttonState = digitalRead(buttonPin); if (buttonState == HIGH) { // add to timer tastyTimeVariable = tastyTimeVariable + 1; digitalWrite(led10Pin, HIGH); } else { }
delay(1000); digitalWrite(led10Pin, LOW); digitalWrite(led9Pin, LOW); digitalWrite(led8Pin, LOW); digitalWrite(led7Pin, LOW); digitalWrite(led6Pin, LOW); digitalWrite(led5Pin, LOW); digitalWrite(led4Pin, LOW); digitalWrite(led3Pin, LOW); digitalWrite(led2Pin, LOW); digitalWrite(ledPin, LOW);
delay(1000);
if (tastyTimeVariable == 0) { }
else if (tastyTimeVariable == 1) { digitalWrite (ledPin, HIGH); delay(300L * 1000L); for (i=0; i < 20; i++) { analogWrite(speakerOut,128); delay(250); digitalWrite(speakerOut, LOW); delay(250); } } else if (tastyTimeVariable == 2) { digitalWrite (led2Pin, HIGH); digitalWrite (ledPin, HIGH); delay(300L * 1000L); digitalWrite (led2Pin, LOW); delay(300L * 1000L); for (i=0; i < 20; i++) { analogWrite(speakerOut,128); delay(250); digitalWrite(speakerOut, LOW); delay(250); } //sound alarm }
else if (tastyTimeVariable == 3) { digitalWrite (led3Pin, HIGH); digitalWrite (led2Pin, HIGH); digitalWrite (ledPin, HIGH); delay(300L * 1000L); digitalWrite (led3Pin, LOW); delay(300L * 1000L); digitalWrite (led2Pin, LOW); delay(300L * 1000L); for (i=0; i < 20; i++) { analogWrite(speakerOut,128); delay(250); digitalWrite(speakerOut, LOW); delay(250); } //sound alarm } else if (tastyTimeVariable == 4) { digitalWrite (led4Pin, HIGH); digitalWrite (led3Pin, HIGH); digitalWrite (led2Pin, HIGH); digitalWrite (ledPin, HIGH); delay(300L * 1000L); digitalWrite (led4Pin, LOW); delay(300L * 1000L); digitalWrite (led3Pin, LOW); delay(300L * 1000L); digitalWrite (led2Pin, LOW); delay(300L * 1000L); for (i=0; i < 20; i++) { analogWrite(speakerOut,128); delay(250); digitalWrite(speakerOut, LOW); delay(250); } //sound alarm } else if (tastyTimeVariable == 5) { digitalWrite (led5Pin, HIGH); digitalWrite (led4Pin, HIGH); digitalWrite (led3Pin, HIGH); digitalWrite (led2Pin, HIGH); digitalWrite (ledPin, HIGH); delay(300L * 1000L); digitalWrite (led5Pin, LOW); delay(300L * 1000L); digitalWrite (led4Pin, LOW); delay(300L * 1000L); digitalWrite (led3Pin, LOW); delay(300L * 1000L); digitalWrite (led2Pin, LOW); delay(300L * 1000L); for (i=0; i < 20; i++) { analogWrite(speakerOut,128); delay(250); digitalWrite(speakerOut, LOW); delay(250); } //sound alarm } else if (tastyTimeVariable == 6) { digitalWrite (led6Pin, HIGH); digitalWrite (led5Pin, HIGH); digitalWrite (led4Pin, HIGH); digitalWrite (led3Pin, HIGH); digitalWrite (led2Pin, HIGH); digitalWrite (ledPin, HIGH); delay(300L * 1000L); digitalWrite (led6Pin, LOW); delay(300L * 1000L); digitalWrite (led5Pin, LOW); delay(300L * 1000L); digitalWrite (led4Pin, LOW); delay(300L * 1000L); digitalWrite (led3Pin, LOW); delay(300L * 1000L); digitalWrite (led2Pin, LOW); delay(300L * 1000L); for (i=0; i < 20; i++) { analogWrite(speakerOut,128); delay(250); digitalWrite(speakerOut, LOW); delay(250); } //sound alarm } else if (tastyTimeVariable == 7) { digitalWrite (led7Pin, HIGH); digitalWrite (led6Pin, HIGH); digitalWrite (led5Pin, HIGH); digitalWrite (led4Pin, HIGH); digitalWrite (led3Pin, HIGH); digitalWrite (led2Pin, HIGH); digitalWrite (ledPin, HIGH); delay(300L * 1000L); digitalWrite (led7Pin, LOW); delay(300L * 1000L); digitalWrite (led6Pin, LOW); delay(300L * 1000L); digitalWrite (led5Pin, LOW); delay(300L * 1000L); digitalWrite (led4Pin, LOW); delay(300L * 1000L); digitalWrite (led3Pin, LOW); delay(300L * 1000L); digitalWrite (led2Pin, LOW); delay(300L * 1000L); for (i=0; i < 20; i++) { analogWrite(speakerOut,128); delay(250); digitalWrite(speakerOut, LOW); delay(250); } //sound alarm } else if (tastyTimeVariable == 8) { digitalWrite (led8Pin, HIGH); digitalWrite (led7Pin, HIGH); digitalWrite (led6Pin, HIGH); digitalWrite (led5Pin, HIGH); digitalWrite (led4Pin, HIGH); digitalWrite (led3Pin, HIGH); digitalWrite (led2Pin, HIGH); digitalWrite (ledPin, HIGH); delay(300L * 1000L); digitalWrite (led8Pin, LOW); delay(300L * 1000L); digitalWrite (led7Pin, LOW); delay(300L * 1000L); digitalWrite (led6Pin, LOW); delay(300L * 1000L); digitalWrite (led5Pin, LOW); delay(300L * 1000L); digitalWrite (led4Pin, LOW); delay(300L * 1000L); digitalWrite (led3Pin, LOW); delay(300L * 1000L); digitalWrite (led2Pin, LOW); delay(300L * 1000L); //sound alarm } else if (tastyTimeVariable == 9) { digitalWrite (led9Pin, HIGH); digitalWrite (led8Pin, HIGH); digitalWrite (led7Pin, HIGH); digitalWrite (led6Pin, HIGH); digitalWrite (led5Pin, HIGH); digitalWrite (led4Pin, HIGH); digitalWrite (led3Pin, HIGH); digitalWrite (led2Pin, HIGH); digitalWrite (ledPin, HIGH); delay(300L * 1000L); digitalWrite (led9Pin, LOW); delay(300L * 1000L); digitalWrite (led8Pin, LOW); delay(300L * 1000L); digitalWrite (led7Pin, LOW); delay(300L * 1000L); digitalWrite (led6Pin, LOW); delay(300L * 1000L); digitalWrite (led5Pin, LOW); delay(300L * 1000L); digitalWrite (led4Pin, LOW); delay(300L * 1000L); digitalWrite (led3Pin, LOW); delay(300L * 1000L); digitalWrite (led2Pin, LOW); delay(300L * 1000L); //sound alarm } else if (tastyTimeVariable == 10) { digitalWrite (led10Pin, HIGH); digitalWrite (led9Pin, HIGH); digitalWrite (led8Pin, HIGH); digitalWrite (led7Pin, HIGH); digitalWrite (led6Pin, HIGH); digitalWrite (led5Pin, HIGH); digitalWrite (led4Pin, HIGH); digitalWrite (led3Pin, HIGH); digitalWrite (led2Pin, HIGH); digitalWrite (ledPin, HIGH); delay(300L * 1000L); digitalWrite (led10Pin, LOW); delay(300L * 1000L); digitalWrite (led9Pin, LOW); delay(300L * 1000L); digitalWrite (led8Pin, LOW); delay(300L * 1000L); digitalWrite (led7Pin, LOW); delay(300L * 1000L); digitalWrite (led6Pin, LOW); delay(300L * 1000L); digitalWrite (led5Pin, LOW); delay(300L * 1000L); digitalWrite (led4Pin, LOW); delay(300L * 1000L); digitalWrite (led3Pin, LOW); delay(300L * 1000L); digitalWrite (led2Pin, LOW); delay(300L * 1000L); for (i=0; i < 20; i++) { analogWrite(speakerOut,128); delay(250); digitalWrite(speakerOut, LOW); delay(250); } //sound alarm } else if (tastyTimeVariable > 10) { } }
Step 4: Finishing
After uploading the code find a place to set it up in your kitchen and when its time to cook you can click the button multiple times to set the time duration. Each click represents 5 minutes (1 click = 5 minutes, 2 clicks = 10 minutes).
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
