Linkit One Power Supply
2,243
33
Posted in TechnologyMicrocontrollers
Introduction: Linkit One Power Supply
About: Eat*Sleep*Code Repeat
If you have your own Linkit One, it comes with a battery in the box and it is powered by a micro USB cable which also charges the battery. But unlike a arduino it does not have a on board voltage regulator so we can not connect it to an external battery source. I personally like to power the board using a 9V external battery and this is made possible by building a 5V voltage regulator.
Step 1: Requirements
Here is a list of all the electronic components required to get started with the circuit.
LinkIt One
L7805 5V voltage regulator IC
10uf Capacitors
PCB
Breadboard
Connecting Wires
Step 2: L7805​
The L7805 is a popular voltage regulator IC it gives an output of 5V at 1A. This is the same IC found on the Arduino UNO board, I have used a ready to use circuit and the circuit is fairly quite simple to build. The IC is capable of regulating input voltages from 5V to 24V, so I can hook up a 9V battery to most of my projects.
Step 3: Circuit
The circuit is very simple and can be found above, it consists of three components, you can also add diodes and build up an rectifier if you are planning to connect an transformer to the input to the L7805. There is no Vin pin in the Linkit One as we have on the Arduino so we will be using the 5V pin. You can also solder the terminals of the voltage regulator to the terminals of where the battery pins are located in the Linkit one board.
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    Awesome post for persons new to microcontrollers.
    This video also aided me in the knowledge of regulators.
    https://youtu.be/GSzVs7_aW-Y
