Linoleum Block / Printmaking by Hudson Hill
Featured
Please Rate my "Instructable"- Enjoy the World of Printmaking!
"Linocut" is a printmaking technique, a variant of woodcut in which a sheet of linoleum (sometimes mounted on a wooden block) is used for the relief surface. A design is cut into the linoleum surface with a sharp knife, V-shaped chisel or gouge, with the raised (uncarved) areas representing a reversal (mirror image) of the parts to show printed. The cut areas can then be pulled from the backing. The linoleum sheet is inked with a roller or (called a brayer), and then impressed onto paper or fabric. The actual printing can be done by hand or with a press
All images under Copyright.
Step 1: Materials
Materials:
Pen, Marker, Pencil
Linoleum block (linoleum glued to a block of wood)
Wooden boards and screws
Tracing Paper
Transfer Paper
Linoleum-cutting tool
Printers ink
Brayers
Electric Blanket and Towel (Linoleum is easier to cut when warm)
Rubber Gloves
X-acto Knives
Blue Painters Tape
Light Box
MIneral Spirits
Vegetable Oil
Wooden Spoon
http://www.imcclains.com/
http://www.graphicchemical.com/
http://www.printmaking-materials.com/
http://www.dickblick.com/categories/printmaking/
http://www.misterart.com/
Step 2: Research Linoleum Artists
Research the Techniques of Linoleum Artists.
Here is some history.
The first relief prints can be found in cave paintings. Early man would dip his/her hands in pigments then touch the cave walls. Your fingerprint is an example of a relief print even a muddy footprint can be considered a relief. Early civilizations used of round "cylinder seals" for rolling an impress onto clay tablets goes back to early Mesopotamian civilization before 3,000 BC. The earliest woodblock printed fragments to survive are from China and are of silk printed with flowers in three colours from the Han dynasty (before AD 220 ). In India the main importance of the technique has always been as a method of printing textiles, which has been a large industry for centuries. In late 10th century China the complete Buddhist canon Tripitaka of 130,000 pages was printed with blocks, which took between 1080 and 1102, and many other very long works were printed. Block-books, where both text and images are cut on blocks, appeared in Europe in the 1460s as a cheaper alternative to books printed by movable type.
Linoleum was a 20th-century development in the art of relief cuts. The linoleum block consists of a thin layer of linoleum mounted on wood; in this the design to be printed is cut in the same manner as for a woodcut. The advantage of linoleum cuts lies in the softness of the material and the consequent ease with which it can be cut.
Irving Amen, American artist
Valenti Angelo, American printmaker & illustrator
Walter Inglis Anderson American artist
Sybil Andrews English/Canadian artist
Georg Baselitz, German artist
Angel Botello, Spanish-Puerto Rican artist
Carlos Cortez American poet and artist
Stanley Donwood, British artist (most famous for his work with British band Radiohead). His work for Thom Yorke's album The Eraser was originally done in linocut.
Bill Fick, American printmaker & illustrator
Jacques Hnizdovsky, Ukrainian-American printmaker, painter, book illustrator and ex libris designer
Henri Matisse, French painter
Pablo Picasso, Spanish painter
Cyril Edward Power, British artist
Ken Sprague, English artist and activist
Folly Cove Designers American design collective
John Paige English artist and member of the Society of Wildlife Artists
Angie Hani artist in the American International School Of Kuwait, Famous Artist
M. C. Escher, Dutch artist known for his mathematically inspired works
John Steins, Canadian artist
Mark Andrew Webber, British Artist, Most famous for his Linocut Map Series of different cities. Also created the New Media Technique of Linomation, which is Hand carved Animation from linoleum.
Step 3: Subject Matter
Find and image that you want to cut into the linoleum. Internet search engines are perfect for this task. The library is even better you can take out entire books of images and scan them in high resolution. Normally I scan images in 300dpi. This allows me to stretch the image to the exact size I need without losing much quality. You can also use a personal drawings or sketches. Just remember if you use an original drawing you may ruin it when tracing it on the linoleum. I suggest making a copy of it. If you know how to use Adobe software that will come in handy. Illustrator and Photoshop are the most useful. Raise the contrast and brightness on the image so there is an obvious difference between the subject matter and the background or what is being cut away. You can also free draw on the block. But remember you have to draw your design backwards.
Step 4: Trace Image on Linoleum
1. Change the image to the necessary dimensions.
2. Reverse the Image on its vertical axis.( The image should be opposite when transferring to linoleum so it prints correctly)
3. Print out the image you can also bring the file on a usb drive to a print shop they usually can print any size you want so you can fit your block no matter what the size.
4. Tape transfer paper on the block. Then tape the printout on top. Only place the tape on the top of the print so you can flip as you trace and see the parts that have already been transferred. Sort or like a hinge. So you can fold the paper back easily and it will lay back down in the same exact place.
5. Use a pencil for this because pens rip through the paper.
6. After the image is transferred go over the lines with a fine permanent marker.
7. Sometimes I take a photo of the traced image. Open it in Photoshop/ Edit/Transform/ Flip Horizontal so you can see the tracing as it will finally appear as a print.
Step 5: Cutting
The first step involves cutting away the white areas of the image. Linoleum printing is essentially a form of stamp printing, so whatever is cut out of the block will not be inked. The cutting tools are V-shaped and U-shaped gouges. ALWAYS CUT AWAY FROM YOURSELF. Cut slowly and and with a smaller gauge. When linoleum gets warm and you have sharp tools it cuts very smoothly and quickly if you slip you can really hurt yourself. I learned the hard way and have the scars to prove it. Just like any blade the sharper it is the easier it is to use and with less effort so sharpen your tools after every project.
This is when the electric blanket comes into play. Place a towel on your workspace then place the electric blanket on a very low setting. Place another towel on top and flip the block face down so you can warm the linoleum so it becomes easier to cut if you do not warm the block the linoleum will flake and your lines will not be precise.
1 is a angled pointed tool and is used for fine lines. This is the tool you use to go around the outline of the stamp you will carve. You may substitute this tool for a craft knife.
2 is a V shaped tool and leaves a fine line in the lino. This tool is essential to lino carving.
3 is a small curved too and again is pretty much essential. It removes a medium amount of lino.
4 is a flat chisel and removes a large area of lino.
5 is a large curved tool and is used for removing larger areas of lino. If you are only planning on making small of intricate stamps this tool can be omitted.
6 Is for straight cuts
You should hold the tool firmly in your hand with your index finger about where the blade is inserted into the handle this helps control. Cutting should be at a 30 degree angle. Buy an extra piece to practice cutting on. Because once you make a cut you cannot fix it easily.
Step 6: Sharpening
Keeping your tools sharp is very important. I suggest you buy a good set of Japanese Woodcutting tools. They are expensive but they will last many years and are high quality. They are very useful not only for linoleum but obviously wood and also pumpkin carving. Many of the high end Japanese Woodcutting tools are made with the same expertise as samurai blade. But I understand most people won't buy expensive tools as a beginner. I use Speedball and Alvin Blades mostly. They are also cheap enough to buy a new blades when they get dull.
But just as easily re sharpened.
You will need a sharpening stone of some kind. There are basically three types available, oil stones, water stones. Whichever type you choose, don't be afraid to buy a decent quality stone, they will last pretty much forever with decent care.
Oil stones are probably the most common. They are abrasive stones intended to be lubricated by oil when being used. They are the least expensive and most commonly available, and provide perfectly good results. Use a sharpening oil, or a general purpose oil, to lubricate them. They are available in many different grits, and also in double sided versions that offer a coarse side and a finer side. I recommend a double sided stone, with a coarse and medium grit (100/700 is a good combination and my preference). If you can only get one grit, go for a finer (700 or so).
Another item that you should keep at hand is a leather strop. They come in handy when you are sharpening, to hone the tool to a fine edge, but they are also great to keep by your side while you are cutting. Running the tool over the strop every so often helps to keep the edge sharp, and will dramatically reduce the time between required sharpenings. A bit of stropping compound also comes in handy.
I prefer water stones. They cost a little more, but they are worth it. You use water to lubricate them rather than oil. Most of them are soaked in a 'bath' of water prior to use. Keep yours in a Tupperware container all the time, so it is always ready to go. They are used in pretty much the same way as an oilstone. Like oilstones, they are available in many grits, I like a 800 and 4000 myself, it allows me to get a very fine edge on my tools. Also, since they don't use oil, the cleanup is a bit easier and you don't end up with oil on your hands, workbench, and linoleum blocks
Look at the diagram
The first picture is a front view of the stone.
The Second and Third are Side views
Begin to sharpen the blade by drawing it in one direction along the stone. You will want to hold it at about a 30-45 degree angle depending on the edge you are after (this is personal preference - some like a sharper angle). Keep the entire width of the cutting edge in contact with the stone to get an even edge.
When you have the edge you want, run it over a leather strop block a few times to fine hone it. You can test the blade in a scrap piece of linoleum or wood, to make sure it 'behaves' as you want it to. You might need to fine-tune the edge.
Step 7: Proofing/ Inking
This is a very important step. Proofing is printing the block before it is completed. This is important because it will show you the flaws in the block and you can fix them. Save your brown paper bags from the supermarket they are great way to do proofs without wasting paper. Save some trees.
Inking the block
Set out your materials: you'll need your block (or blocks), an ink roller, a container with a smooth surface (such as a glass pie plate), ink, and your paper.
Glass Pie Dishes are great because they are pretty cheap and you can have multiple dishes with different color inks. (Remember print lighter colors first and give each color its own roller)
Step
Put on rubber gloves and wear clothes you don't care about ( Oil ink is permanent!)
Step
Dust off your linoleum block with a paper towel or clean rag ( Wipe away all cut out pieces of linoleum, because they will stick to the roller and it is annoying and will ruin a print)
Step
Squeeze some ink onto your smooth surface use a paint knife to spread or popsicle sticks. ( If you plan on printing the future buy some tins of ink. They are a little more expensive ( they last "forever" if you keep them closed when not in use). Start with a small amount of ink and add more if you need to. Think about it, if you add more then you need you waste more ink plus you have more to clean.
Step
4
Roll it around with the roller until the roller is evenly and thinly coated ( It should sound like velcro ripping apart when you have the right amount of ink on the roller, too much ink on the roller leaves blobs of ink too little gives a faded print)
Step
5
Roll the roller back and forth over your linoleum block until the entire surface of the linoleum is coated.
Step
6
Set the roller down ( Upside down) Because you will get globs ink on the roller.
Step
7
Be sure your block is anchored correctly. I just get a piece of carpet and cut it to the size of the block and velcro it to the workspace. Then the block won't slide around.
Step
8
Make sure your hands are clean! Meaning no ink( i use Vegetable Oil to clean my hands. Pick up the paper by the corners and lay it down on the inked block.
Step
9
Press gently ( Use a brayer or I use the back of a wooden spoon and rub it gently on the paper), but do not wiggle or twist the block - if you twist, the design will smear.) You can also use a press if you have access to one. Read directions because every press is different and they are expensive and you don't want to ruin one. The point is to get the ink transferred to the medium.
Step
10
Lift the paper off the block and set it down and inspect for flaws. Flaws are great keep all your misprints because you can learn from them.
Step
11
Place the paper in a safe, clean place to dry.(Buy a drying rack) Or Make one yourself! Or You can take a piece of string and thumbtack both sides to opposing walls so it is tight and get some clothes pins and clip up the prints.
Step
12
After every print you must re-ink the block or it will be a faded print.
Look at the design and if you are happy with it give it about 3 to 4 days to dry to be safe. Oil ink takes a while to dry up. Do not stack the prints til they are dried completely. Hanging them works best for me they stay out of the way. I suggest even longer dry time for fabrics about 1 week.
Step 8: Cleanup
CLEAN-UP CHEAT SHEET
Wear Gloves! Turn on the ventilation! Open Windows!
1. Scrape
Scape up all ink with razor scraper and put it on a phone page.
Roll out roller and scrape up the excess ink. Repeat.
2. Veggie Oil
Pour some vegetable oil on the glass slab. Roll the inking rollers in the oil.
Wipe up the ink with paper towels. Try to use recycled paper towels or I usually just cut up old T-shirts . Wipe down the ink knives and rollers. MAKE SURE YOU CLEAN THEM WELL. There is nothing worse then spending all that time and your beautiful print has a random blob on it. Use Veggie Oil on your Block too.
3. Simple Green
Spray Simple Green on the glass( The reason I say use Simple Green is some people use Mineral Spirits and if you are doing this for a while you don't want to breath the fumes from Mineral Spirits). Use cut up T-Shirts clean the ink and oil from the glass and ink knives. Make sure all surfaces are clean and free of ink and oil including ink knife edges and handles!
4. Roller Wash
(This Step can be skipped if you did a great job on cleaning off all the ink, but if you forgot to clean your rollers and there is dried ink on them this will dissolve the dry ink). (Get a glass pie dish and add just enough Mineral Spirits to coat the bottom it doesn't take much) And roll them around to coat for about 10 min it should come off easy.
Use Ventilation and Gloves!
5. PUT EVERYTHING AWAY -
SUBSTANCES USE TO CLEAN
Vegetable Oil -Ink
Simple Green -Ink, Vegetable Oil
Mineral Spirits- Ink, Asphaltum, Hard/Soft Ground, Tape Residue
Denatured Alcohol- Intaglio Stop Out, Sharpie Marker, Rosin, Ink
Acetone- Tape Residue, Deep Cleaning Litho Plates, Deletions
Roller Wash- Cleans and rejuvenates rubber rollers
Use pumice soap to get ink off your hands.
Step 9: Enjoy!
Contact me for further assistance or to buy prints and original signed artwork. All images under Copyright.
 Please Rate and Comment/ This is my first Instructable.
1-40 of 47Next »
aprintmaker says: Dec 9, 2012. 11:03 AM
Nice stuff, always fun seeing others work and tips. I am also a paper on top printmaker, and I use my hand as the press after trying many other tools I find that the good old press down finger and slowly swirl outwards method is best for me.
dcullen2 says: Nov 12, 2011. 2:47 PM
Thanks so much for this. The two most useful tips I took from this that I haven't seen elsewhere - keep the block stationary and place the paper on top. I was doing it the other way with much worse results. Also - using the back of a wooden spoon to press the paper down - genius. Works like a charm. Who needs a printing press.
Thanks again.
Hudson Hill (author) says: Nov 12, 2011. 11:15 PM
Thank you for the kind words glad I could help. If you have an extra moment post a photo so I can see your final product. Good luck, If you really want to get away from the press and get tired of the wooden spoon run the print/block over with your car.
Cheers
ab
dcullen2 says: Nov 13, 2011. 3:16 AM
Haha, I'll bear that in mind. Here's the print. First one since high school! The rest of my work is up here: http://www.spellingmistakescostlives.com
Cheers!
sonhja says: Jun 17, 2009. 6:30 PM
I have a very hard time using transfer paper Is there any more tip's you can share? Love your how to.
Preistt says: Aug 30, 2011. 7:11 PM
I usually rub the back of my printout with a large piece of graphite I got at the local arts store. Then, I use the printed sheet as a transfer paper, as the graphite will move to the lino when the image is traced.
Hudson Hill (author) says: Jan 22, 2010. 10:59 AM
Sorry it kinda took so long to get back to you. As far as know you should make sure you keep it taped down very well this helps the paper from ripping
Ninzerbean says: Sep 4, 2009. 3:57 AM
There is transfer paper you can run through your printer (!) that can be used over and over - look around this site, it sells it for about $4/pkg. I have not tried it but I know I will.
Jafafa Hots says: Jul 28, 2011. 8:02 PM
A couple of ideas.
First, for correcting mistakes, try JB Weld. An easy mix epoxy, cheap at any hardware and auto supply store, and can be sanded. Could be used to fill in mistakes.
Second - for transferring images that don't have fine detail, print backwards on a laser printer, place face down on the lino and and use a blender marker from the art store on the back, will transfer the toner to the lino very quickly and easily.
Acetone will also work, may work even better for finer detail, but is messier, more of an outdoor job.
Lastly, for softening for carving, try a heat gun very very very carefully (they get HOT) or a hair dryer (not as hot).
Hudson Hill (author) says: Aug 3, 2011. 5:03 PM
Thanks for the tips!
dotbinmo says: Mar 17, 2011. 11:10 PM
WOW! grest pieces!
Your tutorial is great, too.
Story:
(Big difference from when I was in 5th grade...the teacher came in with a stack of ready-made linoleum blocks, a simple v knife , and a very simple, a few lines drawn-on the linoleum pic for us to "carve" with supervision/assistance of her or the aides...then we used a brayer to spread paint on it, turned it on paper, and volia!...prints!
BUT... for a kid it was fun.
They let us keep the print, but collected the blocks)
Hudson Hill (author) says: Jan 18, 2011. 8:52 AM
http://www.wix.com/anthonybopp/2011
mj77 says: Dec 1, 2010. 5:01 AM
The prints are amazing.. but the blocks are even more beautiful in their own right! Great work and very inspiring!
mikoto says: Nov 9, 2010. 6:55 PM
Amazing detail! I am very impressed with how clean your prints are. There is definitely a lot of patience in your work. I just love finding new media to work with. You have my vote and piqued my interest in a new project.
Thank for the great Instructable.
Hudson Hill (author) says: Nov 9, 2010. 7:07 PM
Thanks for your kind words.
Cheers
a.bopp
nickodemus says: May 5, 2010. 5:01 PM
Great 'ible, but what's with the publish date? It says it was published today, but some of the comments are from at least 2009.
Thousand says: Feb 24, 2010. 9:48 AM
 Great Work! Do you have any prints for sale?
erronius says: Dec 22, 2009. 4:44 PM
What gorgeous, elaborate work!
In grade school we just threw the linoleum in an oven for a few minutes to heat it up (but your electric blanket innovation sounds friendlier).  A towel or pot holder is a good idea if the linoleum gets too warm to handle.  Note that some linoleum comes already mounted on a wooden block.  If the block is particle board, it may give off nasty fumes, like formaldehyde, when heated; so either work in a well-ventilated area or stick to unmounted linoleum.
thanks for all of the good, detailed information and memory joggers!
keep doing such great work!
gotclaws19 says: Oct 17, 2009. 2:39 PM
Very good Guide. However on the clean up, Simple Green is very bad for you.
DIYDragon says: Jun 4, 2009. 3:20 PM
I remember doing these a long time ago in elementary school. but we only did single color prints. Would be interested in seeing your tips for multi-colored work. I might make something nifty with that. : D
static says: Jun 3, 2009. 12:53 AM
I boogied on over to you tube to look for any demos that might be there, there isn't anything worth being called a demo pleas consider video recording some demos. thanks...
Speedmite says: May 31, 2009. 6:25 PM
These are cool. Made a small one in like the 3rd grade. It sucked but it was fun. Gifted and talented art has a few good twists. I forgot if I cut my finger a little or if my friend did.....(mind straining)............I think it was me. Well I dont remeber for sure but i remember somone getting a minor cut. Oh well.......
benz_z says: May 25, 2009. 6:13 PM
urs are amazing this stuff hurts i have scars from when i did one of bob marley just last semester person in my class had to go to the hospital and get stiches but that was cause the tools were dull and our school thought it was better to get a press instead of betting decent curved knifes
Father Christmas says: May 25, 2009. 6:33 PM
well, my school thought it better to remodel half of it than to buy computers capable of loading google.com faster than three minutes.
benz_z says: May 30, 2009. 8:13 AM
lol
rgsquared says: May 30, 2009. 7:42 AM
wow-beautiful work! Thanks for taking it through step-by-step. I love doing lino work, and have never taken a class on it. Your clue of the contact paper was key to my success in my current lino block stuff. I'll upload pics when I get them done. Again, Thanks! This art form is very beautiful to me. Rachel rgsquared@gmail.com
jtobako says: May 25, 2009. 8:46 PM
Sharpening gouges?
Sooz says: May 28, 2009. 9:33 PM
It's the type of cutting tool from which the action of gouging is derived. :)
http://en.wikipedia.org/wiki/Gouge
jtobako says: May 29, 2009. 11:27 AM
Sharpening (v), as in 'how to' as it's an important part of the instructable that is missing.
bethmwl says: May 29, 2009. 5:15 AM
Fantastic artwork, you should do an instructable for the skeleton face!
skachati says: May 29, 2009. 4:14 AM
you are very good master... thanks
kyannik says: May 28, 2009. 5:32 PM
I've always wanted to give this a try. Your work is beautiful. Thanks for sharing!
locofocos says: May 28, 2009. 2:41 PM
Nice instructable! I did this in art class a few years ago. I will go ahead and say that doing a multiple color linoleum block print is rather difficult during the cutting and during the printing process.
robbs says: May 28, 2009. 1:54 PM
WOW..great job! It looks labor intensive. Is there a youtube tutorial? I don't quite understand the tracing procedures. Sad, to say, this instructable is a bit much for me. Thanks for sharing!!!
jeoncs says: May 28, 2009. 9:46 AM
this is really cool
mtjohnson6 says: May 28, 2009. 6:49 AM
WOW!!! Don't take this the wrong way...but, to me...it is VERY Ed Hardy on speed!!! And I REALLY do LOVE it!! I LOVE, LOVE, LOVE your work!! Would you consider selling me one of your blocks???
justin_the_jack says: May 28, 2009. 6:18 AM
I love your artwork! Especially the spiralling rays stuff. Good instructable, too! Can't wait for the multiple colors one.
klynslis says: May 28, 2009. 5:32 AM
Great tut and great work! I hope that you cover your inking processes (with the multiple colors on a single pass) in subsequent tutorials. ::applause::
DragonRampant says: May 27, 2009. 11:09 PM
really nice work. did you do the prints on t-shirts or did you have them printed for you. if you did them, how did you print them, and how did you prepare your artwork to be printed?
Chaz-imus says: May 27, 2009. 8:30 AM
Soy based cleaners work really well too.
1-40 of 47Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
