"Linocut" is a printmaking technique, a variant of woodcut in which a sheet of linoleum (sometimes mounted on a wooden block) is used for the relief surface. A design is cut into the linoleum surface with a sharp knife, V-shaped chisel or gouge, with the raised (uncarved) areas representing a reversal (mirror image) of the parts to show printed. The cut areas can then be pulled from the backing. The linoleum sheet is inked with a roller or (called a brayer), and then impressed onto paper or fabric. The actual printing can be done by hand or with a press
All images under Copyright.
Remove these ads by
Signing UpStep 1Materials
Pen, Marker, Pencil
Linoleum block (linoleum glued to a block of wood)
Wooden boards and screws
Tracing Paper
Transfer Paper
Linoleum-cutting tool
Printers ink
Brayers
Electric Blanket and Towel (Linoleum is easier to cut when warm)
Rubber Gloves
X-acto Knives
Blue Painters Tape
Light Box
MIneral Spirits
Vegetable Oil
Wooden Spoon
http://www.imcclains.com/
http://www.graphicchemical.com/
http://www.printmaking-materials.com/
http://www.dickblick.com/categories/printmaking/
http://www.misterart.com/
Thanks again.
Cheers
ab
Cheers!
First, for correcting mistakes, try JB Weld. An easy mix epoxy, cheap at any hardware and auto supply store, and can be sanded. Could be used to fill in mistakes.
Second - for transferring images that don't have fine detail, print backwards on a laser printer, place face down on the lino and and use a blender marker from the art store on the back, will transfer the toner to the lino very quickly and easily.
Acetone will also work, may work even better for finer detail, but is messier, more of an outdoor job.
Lastly, for softening for carving, try a heat gun very very very carefully (they get HOT) or a hair dryer (not as hot).
Your tutorial is great, too.
Story:
(Big difference from when I was in 5th grade...the teacher came in with a stack of ready-made linoleum blocks, a simple v knife , and a very simple, a few lines drawn-on the linoleum pic for us to "carve" with supervision/assistance of her or the aides...then we used a brayer to spread paint on it, turned it on paper, and volia!...prints!
BUT... for a kid it was fun.
They let us keep the print, but collected the blocks)
Thank for the great Instructable.
Cheers
a.bopp
In grade school we just threw the linoleum in an oven for a few minutes to heat it up (but your electric blanket innovation sounds friendlier). A towel or pot holder is a good idea if the linoleum gets too warm to handle. Note that some linoleum comes already mounted on a wooden block. If the block is particle board, it may give off nasty fumes, like formaldehyde, when heated; so either work in a well-ventilated area or stick to unmounted linoleum.
thanks for all of the good, detailed information and memory joggers!
keep doing such great work!
http://en.wikipedia.org/wiki/Gouge
