Remove these ads by
Signing UpStep 1Basic Terminal Commands
cal-display a calendar
cat-display contents of a file
cd-change directory
chmod-change access permisions
clear-clear the terminal screen
cp-copy file(s) to another location
date-display date
echo-display a message in the terminal screen
exit-close the terminal window
find-search for file(s)
install-(this is where common sense is used...)
ls-list info for file(s) from whatever directory you are in
man-help
netstat-displays network statistics
ping-test network connection
su-change to root user
su (user name)-change to name in parentathes
wget-retrieve files from the internet
everyone sems to get ride pc well before there usefullness is really used up. i was amazed how linux recognized my dvd usb port and video card licity split my monitor as well but grudgingly. this is great way to use old pc and with all the info in trhe bible and the resources it points out you can have full media pc if you read da book dat is da linux bible book
distro: well mainly, Pardus, & Mandriva
A: Check out this site, that's what I did.
Q: How to scan for available networks?
A: Check this out
If this doesn't help please let me know and I'll try again
At least add how to get help for a cmd using man ( su for instance):
man su
Will return the 'manual' for the su command. Works with the programs (man "cmd") on your list.
