Lion Sentry Upgrade
2,274
31
4
Posted in CraftArt
Introduction: Lion Sentry Upgrade
About: Retired Command Sergeants Major and served in the U.S. Army for 32 years. I am retired retired and just work around the house on projects for the house and holidays. I like to set a good example and inspire ...
The wife had bought two lion sentries a few years ago and they got damaged from the weather so I decided it was time to refurbish the lions since they sat in front of our gate. The lions were an off light blue aqua color. The first thing I did was patch a big hole in the back side of the pedestal using expanding insulating spray foam. I stuffed the hole with broke bits of Styrofoam and then sprayed the expanding insulating spray foam till it came out. I scrapped the excess as it came out ensuring it all was level. I waited a few hours and then came back with a sharp knife and started to cut and trim the excess till it was level. No sanding was needed as the pedestal the lion sits on is stone looking so the spray foam matched perfectly.
Step 1: Black Highlight Coat
I started spray painting the lions with black Rust-o-leum paint and hit the hair, eyes, mouth, paws, in between the legs, curves and anything I thought needed to stand out. I did this with both lions flipping back and fourth in order to give the paint time to settle and dry some. This helped me see if I missed any parts of the lion as well. As you can see I ensured I hit the lions back ribs and spine so that it would standout more and all the shadow areas as well.
Step 2: Metallic Silver Coat
I moved the lions from where they were sitting up on the saw horses down to the grass so I could hit the top of the heads better. Once the black was dry I started with a metallic silver also Rust-o-leum spray paint. I sprayed and tried to hit the areas that stuck out versus the cracks and shaded areas. As needed I touched up the black to ensure the highs and lows all blended in.
Step 3: After
Here is the after photos of the our lions. The entire project took me a day because of the sun shine which helped dry the spray paint very fast. The lions turned out a hole lot better after I was done and now sit proudly guarding my gate as they should be.
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    4 Comments
    Jedi_zombie85, thanks. Please vote for me on the Before and After contest.
    Very nice! I have a few that need touching up as well. I'll have to remember how you used the dark / light paint to make them look even more 3 dimensional.
    katherine1958, I got the idea of using the black paint first from the internet. I made a Grim Reaper and the instructions were to use black first and then the other colors. I used the same concept for the lions. Hope to see yours on the site.
