an easy way to turn an empty liquor bottle into a cool lamp.
Step 2: Drill the hole
wash the empty bottle with warm soapy water so mould doesnt grow when the lamp is done.
drill a hole into the side of the bottle near the bottom. this is where the lamp cord will enter.
only use a drill bit that is meant for cutting glass, a typical bit wont work. if you dont have a glass bit you can pick one up at any hardware store for about $5.
Step 3: Clean the hole
its a good idea to take a file to the edges of the drilled hole. the glass is sharp and could cut the cord which wouldnt be fun.
Step 4: Feed the wire
feed the wire through the drilled hole and pull it out through the top.
Step 5: Connect the socket
strip the ends of the wires and connect them to the screws on the socket
Step 6: Electrical tape
put some electrical tape around the contact points to cover them. you can also keep the tape going and use it to hold the socket tight to the bottle.
1-40 of 43Next »
Hoaxinmi says: Apr 3, 2008. 4:46 PM
Great Instructable. I used an old lamp from a 2nd hand store. I'm having a little trouble finding a lampshade though. The best part is emptying the bottle. This is one of those 1.5 liters. I just kept the cork and drilled a whole in it.
Heywasup in reply to HoaxinmiJun 21, 2008. 11:33 AM
dude seriously everyone knows you can get a lampshade at Ikea!!!!!!!!!!!
Hoaxinmi in reply to HeywasupJun 23, 2008. 7:01 AM
The only Ikea in MI is 2 hours away
Heywasup in reply to HoaxinmiJun 23, 2008. 4:47 PM
Oh lol. Than i suggest you get a lamp and use the shade. Or if you find a goo d one on a lamp in a store u an take it. >:v)
GitarGr8 in reply to HoaxinmiMay 25, 2009. 1:14 PM
I did the exact same thing because I didn't feel that electrical tape was going to be very secure. I just drilled a hole in the cork and used a threaded nipple to attach the harp and socket.
I ended up spending a bunch on parts at Home Depot, but I found that this kit has most of what you need for cheap:
http://www.lampshop.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=R8001&Category_Code=10_02d_PARTS_ELECTRIC_KITS
Great instructable, thanks for sharing.
cm4bleenmb64 in reply to HoaxinmiJul 12, 2009. 9:35 AM
Walmart, K-Mart, Meijer, Dollar General, Family Dollar, thrift shops, etc. Lamp shades are not that hard to find. I wouldn't even be surprised if there are some instructables for making your own!
frenzy in reply to HoaxinmiJun 23, 2010. 1:32 PM
have great news!
This posting has won today's "I Made It" Challenge. For winning you will receive a 3 month pro membership!
Thanks for using instructables!
http://www.instructables.com/community/June-is-I-Made-It-Challenge-Month-Win-a-Pro-Mem/
buzzedupplenty says: Feb 2, 2011. 11:22 PM
such a great idea, should start a business boozelamps.com.
I was going to, but no time, so im offering my domain 2 whoever
is interested...
farflungfloyd says: Jul 11, 2010. 11:45 PM
I've made about 6 of these (they make great gifts). I suggest filling the bottle with something to weigh it down. Otherwise you run the risk of the lamp being top heavy. You can use marbles, nuts and bolts or coloured beads for the filling...
tjpsurman in reply to farflungfloydNov 26, 2010. 8:32 AM
I got the idea to take my 1.75 Jagermeister and do this project. I assumed I would need all of the parts listed above, but I was trying to figure out how I could instead of a traditional switch, get a rheostat to control the lighting. The big idea is to utilize the cap of the bottle as the rheostat, any suggestions on the best place to find one that small? Radioshack was a dive so far.
chucksfc says: Mar 6, 2009. 3:08 PM
if you make the hole a just a little bigger, you can use a rubber grommet or bushing here and do a little less filing - the rubber also protects and secures the wire nicely. These grommets are usually in the small specialty bins or drawers at most hardware stores.
senatorrosewater says: Sep 17, 2008. 3:38 PM
This is super cheap and super fast. took me about an hour, and that included the trip to home depot. this is an awesome product, and if you haven't made it yet, what are you waiting for?
senatorrosewater says: Sep 17, 2008. 3:32 PM
I got a plug at home depot that comes apart with a screw, then used wire strippers to clear the ends of my lamp wire, and bolted them into the new plug. Its easy and clean, and the plug was only $1.99, about the same price as electrical tape.
senatorrosewater says: Sep 17, 2008. 3:23 PM
Since my socket was already hardwired, I found it much easier to run a string up through the drilled hole to the bottle mouth, tie it to the cord, and pull the (plugless) cord through).
senatorrosewater says: Sep 17, 2008. 3:19 PM
Wrap a towel around the bottle (except where you're drilling) if you're holding the bottle in a vise. I stained my label.
senatorrosewater says: Sep 17, 2008. 3:16 PM
I did not need any electrical tape, but used super glue instead. I also used parts from an old lamp, and a brand new plug, although without the new plug, the electrical tape would have been necessary to splice the wires.
Heywasup says: Jun 21, 2008. 11:41 AM
seriously what are the chances of cracking the bottle on a scale of 1-10
nickfarnell (author) in reply to HeywasupJun 21, 2008. 1:33 PM
if you buy the right drill bit and have a little patience your chances of being successful are probably more than 90%. you can get a glass bit from any decent sized hardware store - it looks like a spade (i think there is a pic here somewhere). just go slow and dont apply too much pressure if you use a normal drill bit...your chance of breaking the bottle is pretty close to 100% good luck!
Heywasup in reply to nickfarnellJun 23, 2008. 4:39 PM
Thanks!
XDben says: Jan 6, 2008. 8:05 PM
ok, i'm all but done. really cool project! i might be making one for one of my friends too! just a tip to anyone out there, do what i did to keep this cheap- go to goodwill and pick up an old lamp with a cord with a switch. i bought a black one for about $4 and cut the cord off and stripped the wires. i also took the black lampshade off and the small lightbulb out. so i got probably 15 bucks worth of stuff from one 4 dollar lamp. pretty cool! i'll try and post some pictures of mine some time this week. =]
thanks for the awesome instructable.
nickfarnell (author) in reply to XDbenJan 10, 2008. 4:12 PM
good stuff! cant wait to see the pics
Heywasup in reply to nickfarnellJun 21, 2008. 11:40 AM
excuse me nickfarnell what are the chances of breaking the bottle on a scale of 1-10 i want to use my sisters favorite liquor bottle but i dont want to crack it shell kill me
Doctor What says: Dec 16, 2007. 6:02 PM
My sister collects liquor bottles for some reason. This'll be a good gift for her. (+)
Heywasup in reply to Doctor WhatJun 21, 2008. 11:37 AM
my sister collects bottles too. im making one for her too.
XDben says: Jan 5, 2008. 4:26 PM
cool! i'm making one today for my room wiith a jones soda bottle, i'll be the only one on the block with a GreenApple lamp! ;)
Yerboogieman in reply to XDbenFeb 21, 2008. 8:00 PM
yeah, im using a citronge (orange Patron) for mine
jdpadilla in reply to YerboogiemanMay 17, 2008. 8:03 PM
hey koolaid, what did you use as cap for the patron bottles? I have a few i'd like to turn into oil lamps.]
Yerboogieman in reply to jdpadillaMay 18, 2008. 10:35 AM
i didnt make it yet, but it wasnt a regular patron bottle, it was a square one with a regular cap, i still didnt finish the bottle
XDben in reply to YerboogiemanFeb 22, 2008. 7:37 PM
nice!
sickdog74 says: Apr 5, 2008. 10:29 PM
Cool! You inspired me, I'm gonna make one!
Heywasup says: Apr 5, 2008. 2:30 PM
Sorry i meant sisters
Heywasup says: Apr 5, 2008. 2:29 PM
im making it for my iters 23 birthday
incorrigible packrat says: Mar 13, 2008. 3:33 PM
Yeeaahh! Let's git Tanq'd.
extrememtbr69 says: Mar 13, 2008. 2:18 PM
instead of a glass bit you can use a dremel with a grinding stone to make the hole
mrblusky says: Jan 3, 2008. 4:49 PM
A small hand switch somewhere between the wall socket and bottle end would make it a bit more user friendly too me thinks.
mrblusky says: Jan 3, 2008. 4:44 PM
Me like!,great instructable,pretty much idiot proof.
Shifrin says: Jan 3, 2008. 9:01 AM
Great Instructable!
nickfarnell (author) says: Dec 17, 2007. 5:30 AM
i agree, there could be a better way...but i was shooting for the 15/15 rule. under $15 and under 15 minutes.
SWV1787 says: Dec 17, 2007. 4:42 AM
another thought this would make a great gift for my friend who is turning 21 (legal drinking age here in the states)
SWV1787 says: Dec 17, 2007. 4:41 AM
I think there must be another way to hold the socket in place rather than eectrical tape it looks so... unprofessional. I have a lamp made from an old stoneware whisky jug and it has a larger socket that was hooked to a coller that went through a hole drilled in the cork for the jug. it looks nice but the cork is only press-fit in the jug and it pulls out easy.
1-40 of 43Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
