loading
Step 9: Connect hookup wires and resistors to perfboard
This step is relatively straightforward.  Each of the 10 anode hookup wires need to connect to the perfboard, through a 100 ohm resistor, then to another hookup wire on the other side.  You will also  connect the anodes of each of you colons through a 100 ohm resistor.
Before you start soldering, you need to know exactly where your perfboard and Arduino will mount in the case.  Once you decide on location, you will know how long to make the hookup wires.
To connect to the perfboard, just insert the wires and resistors through the top of the board.  (The top of the perfboard does not have the copper pads).  Twist the leads together and solder.  Try to get solder on and across the pads, and not just the leads.  Watch the video carefully for further instruction.  Feel free to cut your perfboard down, like I did in the video.  Be careful though, the perfboard is very brittle.  I would cut it before I did any work in case the board gets ruined.
The first video "Breadboard Fail" can be skipped.  I try to use a breadboard, which would have been faster.  The hookup wire kept coming out and I decided it was too fragile.  So I ripped the wires out and used a perboard instead.
<p>Congrats on this really awesome and well documented project.</p><p>Do you think that by adding two more vertical columns of LEDs we could turn this into a Military type clock (22:00 instead of 10:00 o clock) ? Are the arduino pins sufficient, or do we need to add more hardware apart from the 8 LEDs and the two resistors? Of course I will need to alter the code....</p><p>I m thinking of starting this project in about a month...</p>
<p>Awesome project! Made mine for a programming class, however there is one thing i recommend: Don't use red LED's they don't show up as nicely as green or yellow. Great instructable!</p>
Thanks a lot for this great tutorial! We made it! <br>There a couple of things I'd like to share with you from our making experience: <br>a) We marked the anodes of each led in advance so it was easier not to get mixed up between anodes and cathodes in the soldering process. <br>b) We discovered an error in the code. The following lines had to be modified for the second colon mark to lite: <br>digitalWrite(column[11],HIGH); <br>digitalWrite(column[12],HIGH); <br>digitalWrite(column[11],LOW); <br>digitalWrite(column[12],LOW); <br> <br>Change them to the following, so they correspond to the Arduino wiring as described above: <br> <br>digitalWrite(column[10],HIGH); <br>digitalWrite(column[11],HIGH); <br>digitalWrite(column[10],LOW); <br>digitalWrite(column[11],LOW); <br> <br>Great job and thanks again!!
This is my first project using Arduino and I am quite new on the programming scene. This is a really great instructable and seems to cover all of the details. Although I have encountered a small problem. I can't seem to program my Arduino with the program which you have provided. The Arduino programmer is telling me that certain lines &quot;Aren't declared&quot;. As I have said, I've never used Arduino before so I have no idea what this means. <br>If you could help me out with this problem I would greatly appreciate it.
Hi there, I encountered the same problem. After some looking in the Arduino guide, I found that the Time.h library was copied to the wrong location. Here's a quote from the guide (source: http://arduino.cc/en/Guide/Libraries): <br>The library won't work if you put the .cpp and .h files directly into the libraries folder or if they're nested in an extra folder. For example: <br> <br> Documents\Arduino\libraries\ArduinoParty.cpp and <br> Documents\Arduino\libraries\ArduinoParty\ArduinoParty\ArduinoParty.cpp <br>won't work. <br> <br>Hope this helps!
Very awesome i been following your video tut for a while now. I'm also building a clock my self right now just wiring it i finish Soldering the anodes and cathodes now onto the wiring. Soon i hope to be finished and try out the coding on this.
I like your project and all the video tutorial. At the beginning of the project you said to pretend it was an Arduino UNO. What would be the code for using the analog inputs on an actual UNO or duemilanove. I asume you would have to change this: int row[] = {14,15,16,17,18}; <br> to something else. I'm a beginner...
Hi, thanks for the kind words. I'm a beginner too!<br><br>The code should work as is. Analog pins A0,A1,A2... can be used as analog or digital pins. You can reference them in your program as either A0,A1.... or as 14,15,16... It will work either way.<br><br>You building a clock? If you endup having trouble, drop me a line and I'll take a look.
Hi, I got really ambitious after viewing tutorials about circular infinity lights. I want to build a clock that is both. <br>thanks for your explanation on how to use analogs as digitals. I will have to scavenge for parts. <br>If i ever get it made I will post some pics.
lol epic music when you were putting the clock down
LOL, didn't even notice it! That music was from the opening cermonies of the Olympics.
Nice Job, I really enjoyed ur detailed explanations which made the job look very easy. <br>I think what i really want is a circuit without Arduino, please show us the circuit with complete chips and the programming
Hi, glad you enjoyed the instructable. The Arduino pin assigments are shown in step 10. Basically, I have the 5 rows of common cathodes going directly to 5 pins on the Arduino. The 10 columns of common anodes each go to a 100 ohm resistor, then to 10 pins on the Arduino. <br> <br>The code is listed in step 12. <br> <br>I'm afraid I can't help you with a non-Arduino design - I'm a beginner myself. Are you looking to go with a different micro-controller, or are you just going to do it with IC logic?
Looking good. Liked the way you presented the whole project.
Thanks! Making the Instructable was a lot more work than I though it would be. Very rewarding though.
Very cool! Now what will your daughter play with? ;)
Supposed to be buying her a new one - haven't done it yet. :) She better be careful - her Powerwheels is looking like a really solid outdoor robot chassis.
It looks awesome. Well done. :)
Thanks!
About This Instructable
32,909views
56favorites
License:
Bio: Electronics are a newly re-found hobby for me. I'm not an engineer - I'm an ordinary guy who likes to tinker with electronics in ... More »
More by meanpc:How to Negotiate at Garage Sales How to Plan Your Garage Sale Route Using Google Earth (for EBay Sellers) Potentiometers and AnalogRead - How to Arduino #4
Add instructable to:
