3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
FlashBack - Backpack, Camelbak or Jersey Integrated LED Bike Flashers
Step 4Create the Hookup
Create the Hookup
Time to solder the wires to the PCB.
1. Solder the power wires, positive and negative battery contacts.
2. Temporarily connect the power wires to the battery. Using a multimeter, measure which side of the power switch contact is positive. Solder a wire to the positive side of the power switch contact. This is the switch wire.
3. Drill a hole in the back case for the wires to exit through.
Note: The flasher module with the switch in the housing needs an extra wiring step to connect the switch. After soldering a wire to the positive side of the power switch contact, wire the switch across the switch contacts on the PCB. When the two switch wires are connected together between the modules, the switch will turn them both on and off simultaneously.
4. Temporarily connect everything together to make sure that it functions properly.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:engineerable
Daniel Bauen breathes new life into objects that have met their untimely demise in the junk pile.
