Little Bunny Foo Foo in His Bed
 by Yarnabees
Contest WinnerFeatured
Step 2: Ears, Legs and Tail
EARS : With A
Rnd 1: Begin work by making a Magic Circle with 6 sc. Place marker in first stitch for beginning of round; move marker up as each rnd is completed.
Rnd 2 - 4:  Sc in each st around. Fasten off leave a tail  sew the open end of the ear closed. Once sewed closed  sew to the top of the head.
TOP LEGS: make 2 with A
Rnd 2-3: Sc in each st around. Fasten off and leave a tail to sew legs to body.
BOTTOM LEGS make 2 with A
Rnd 1: Begin work by making a Magic Circle with 7 sc. Place marker in first stitch for beginning of round; move marker up as each rnd is completed.
Rnd 2-5: Sc in each st around.
Rnd 6: *Sc2tog two times, then sc in the remaining scs. Fasten off leaving a long tail to sew to body.
TAIL:
TAIL: With (C) make a pompom by using a credit/gift card. Begin by wrapping the yarn around the shortest width of the card. Continue to wrap around for 50 times. Cut yarn then cut a piece of (C) yarn 8 inches long and use the blunt needle to insert in between the yarn and the card only pull halfway through. Pull tight towards the top of the card. Tie in a knot, slide the yarn off (once you slide it off it will be loose) then wrap the two strands around once more pulling tight and tie a second knot tighter than the first knot. Cut the loops fluff out, do not trim the strands you used to tie the tail but trim the rest of the tail down to size. Use the two strands to sew the tail to the back of the Bunny.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
