Join the Little Free Library movement by building your own.  Thousands of people have already done so.  Here's an article in our local newspaper about this one.  The size can be anything from a cubic foot up, so there's lots of flexibility in design and materials.
The Little Free Library web site has good tips and plans for builders and I used those as a starting point.  Mine is a little larger and has these design characteristics: Materials:
  • Half sheet of 5/8" exterior plywood for walls, floor, and roof
  • Recycled pine for trim, shelf, and braces
  • Recycled asphalt shingles
  • Recycled aluminum flashing
  • Recycled mirror frame for door
  • Hinges and hook for door
  • Weatherstrip rubber foam self-stick tape for door
  • Clear acrylic for door
  • Push glazier points for door
  • Box of #8 x 1-1/2" flat head brass wood screws
  • Wood glue
  • Caulk
  • Enamel paint for exterior
  • Translucent oil stain for interior
  • Recycled 2x8 for base
  • 4"x6"x8' pressure-treated post
  • Lag screws for post, braces, and base
  • Bag of gravel mix cement
Tools:
  • Circular saw.  A table saw would be even better but I don't have one.
  • Carpenter's square
  • Tape measure
  • 1/4" drill with Phillips bit, drill bits for pilot holes and flat boring bit to counterbore lag screws
  • Phillips screwdriver.
  • Paint brushes and rags
  • Caulking gun
  • Level
  • Socket wrench
Step 1: Draw out your plan
Don't skip this step.  Just thinking through the details and writing them down will save you a lot of mistakes and rework later.  Trust me on this.
You don't need a professional blueprint--just a pencil and paper.  A sheet of graph paper makes this easier.  If you don't have one you can print one from the web
I changed my mind about some dimensions along the way so my plan is mostly to scale.  Notice a few design details:
Step 2: Cut and label the plywood pieces
Follow your plan and revise it as needed.  Measure and cut the walls, floor, and roof boards.  To save problems later, be sure all cuts are square.  Label each piece--otherwise it's easy to get a piece out of place.  Trust me on this.
Brass screws don't rust, but they are soft so pilot holes are important.  Drill them with two different bit sizes.  Holes in the board you are passing through should be the same diameter as the screw shanks.  Holes in the board that the screws are tightened into should be smaller than the screw threads.  Temporarily assemble the pieces to ensure that everything fits correctly.  Hint--place nails in the pilot holes or drive the screws just part way in.
Step 3: Cut and assemble the braces, trim, shelf, and door frame
The roof's end trim pieces fit snugly outside the walls.  Cut the 2"x2" brace for the roof so it fits snugly inside the walls.
The shelf's depth is about 3/4 the depth of the side walls and it rests on braces attached to the side walls.  Position the shelf braces so the shelf has about an inch of clearance below the top brace on the front.
The door frame rests against weatherstrip tape applied to the edges of the side walls, the edge of the floor, the top front brace, and the bottom front brace, so all these surfaces must be flush.  The top front brace is attached to the side walls and the bottom front brace is attached to the floor.
I made the door from a recycled oak mirror frame and cut it down to size.  I used both wood glue and screws to make the two new corners as strong as possible.  Then I cut the clear acrylic window to match the frame.  The clear acrylic can be cut by sawing or by scoring and breaking.  I just used my circular saw with a fine-tooth blade and that worked well.
Step 4: Paint and more paint
Paint all the interior surfaces with your favorite waterproof sealer.  I used a translucent oil stain that I had on hand.  Each joint will be glued as well as screwed, so for best glue adhesion avoid painting the surfaces where the glue will be applied.
Paint all the exterior surfaces.  I applied several coats of Rustoleum exterior enamel.  I also added black paint for the covered bridge look.
Step 5: Assemble the pieces
Apply wood glue and screw the brace and trim pieces to the plywood roof.  Cut the flashing and roofing shingles to fit.  Nail or staple them in place.
Apply wood glue and screw the shelf braces, walls, floor, top front brace, and bottom front brace together.
Step 6: Add the door and caulk the interior
Install the clear acrylic into the door frame with glazier points.  Apply the weatherstrip tape to the edges of the side walls, the edge of the floor, the top front brace, and the bottom front brace.   Attach the door's hook and eye.
Caulk all the inside joints.
Touch up the exterior paint to cover the screw heads.
Add exterior trim pieces if you want yours to look like a covered bridge.  ;-)
Step 7: Build and install the post
Cut a section of 2x8 to match the width of the Little Free Library.  This is the base that rests on top of the post.
Cut off two 12" lengths of the 4"x6"x8' post to make two braces.  Cut the braces at 45-degree angles.  Counterbore each place you will put a lag screw--this will provide clearance around the lag screw head when you tighten it with the socket wrench.  Drill pilot holes for the four lag screws.  Attach the angle braces to the base with lag screws.
Dig a 2' hole and drop in the post.  Pour in the bag of concrete mix and water.  Level the post and let the concrete dry.
Step 8: Install the Little Free Library
Set the angle braces and base on the post.  Level the base and use the socket wrench to tighten the lag screws in the angle braces.
Drill a pilot hole for a lag screw through the base into the post.  Tighten the lag screw to stabilize the base.
Set the library on the base and drill four pilot holes through the floor into the base.  Tighten the four lag screws to secure the library to the base.
Add the roof, the shelf, and the books.  Enjoy your Little Free Library!
makermike says: Aug 9, 2012. 10:18 AM
I'm building a Little Free Library at the moment. One addition I'm putting in is a LED light that turns on when the door opens. Can't wait until it's finished and set up!
alanwbaker (author) says: Aug 9, 2012. 11:48 AM
What a great idea--I wish mine was close enough to electrical power to do that! How about an arduino with wi-fi that counts the number of times the door opens?
makermike says: Jan 26, 2013. 7:59 PM
I hacked a dollar store LED "stick-up" type light to include an external switch that closes when the door opens. Two AAs should run it for quite a while.
doo da do says: Aug 12, 2012. 7:59 AM
You could get battery power or solar if the sun is available. Put a switch on the door.
cpine522 says: Aug 12, 2012. 7:07 AM
How about a idigtal camera that takes the person photo when tehy open teh door and loads it to a website via wifi connection. ? :)
edjez says: Aug 11, 2012. 5:25 PM
Nice idea- Check out the Electric Imp that is coming out to wifi it on the cheap. If you can do that then a little nice connection to IfThisThenThat could make your library tweet by itself or...
Myself on the other hand somehow see a beauty in the little free library being down-to-earth and low-tech. Maybe less data on it could be an attractive mystery.
alanwbaker (author) says: Aug 11, 2012. 6:33 PM
Oooo! The Electric Imp/IFTT idea sounds good--I'd like to use it on another project. But this Little Free Library will continue offline on our unpaved road.
But the concept has caught the imagination of others here in the Green Mountain State--it was just featured on the front page of our local newspaper!
http://www.dvalnews.com/view/full_story/19748114/article-Little-library-lends-literature-liberally
craftmachine says: Aug 28, 2012. 5:14 PM
Very creative! It is a great way to reach out to the community. When I went to Germany I saw one similar to the one you made. I just think that it is both beautiful and will bring the community together to share their favorite reads. Fantastic idea!
ronopotomus says: Aug 15, 2012. 7:47 AM
Awesome idea! I'm gonna give it a go.
bricabracwizard says: Aug 12, 2012. 4:43 PM
I love what you've created! I will be making one for our yard in Sydney, Australia. I first saw your idea on Technabob. Another thought I had was to create a free swap box for geeks to exchange components or ideas.
alanwbaker (author) says: Aug 12, 2012. 5:07 PM
Good on ya, Mate. I'll be in Sydney in February--maybe I'll see your LFL then!
bricabracwizard says: Aug 14, 2012. 9:19 PM
Thanks! Do come and pay us a visit. If you need a place for a couple o' days let me know!
alanwbaker (author) says: Aug 14, 2012. 10:30 PM
Thanks. We'll mostly hang out with bro-in-law in Figtree plus the flash tour of Oz. ;-)
cpine522 says: Aug 12, 2012. 7:12 AM
might alos be fun to onclude book crossing in your projects.http://www.bookcrossing.com
No affiliation it is just fun to watch where you books go.
Hack42Moem says: Aug 12, 2012. 2:22 PM
Hah! I was just going to post that! :-D
Here's my BookCrossing I'ble. And yes, Little Free Libraries and BookCrossing are a match made in booklovers' heaven.
pepperjordan says: Aug 12, 2012. 1:41 PM
I read about these in the Seattle newspaper and really wanted to make one. Great instructable.
bajablue says: Aug 12, 2012. 10:03 AM
I love everything about this project!
Beautiful work, Alan!!!
latexmallard says: Aug 9, 2012. 5:09 PM
Great Idea, We have one set up here in Christchurch, NZ, as part of the Gap Filler project. Putting interesting things in place of buildings that collapsed during or were demolished after our Earthquake. http://www.gapfiller.org.nz/happy-first-birthday-book-exchange-2/
alanwbaker (author) says: Aug 9, 2012. 6:10 PM
I love the fridge! We're going to visit Christchurch in January. Where is it located?
latexmallard says: Aug 12, 2012. 2:52 AM
Currently on the corner of Kimore and Barbadoes Streets, just outside what used to be the CBD. The Gap fillers are likely to move around has more buildings are demolished and the reconstruction starts.
gnomedriver says: Aug 12, 2012. 6:59 AM
We in NZ look forward to seeing you when you come.
There is a free library in Lyall Bay, Wellington.
http://www.catchingthemagic.com/2010/10/my-kind-of-bus-stop-if-only-i-had-the-time-to-linger-there/
It is things like this that keep communities alive. Can’t do that with a Kobo.
blodefood says: Aug 11, 2012. 6:18 PM
Why does it say around the USA when there are many in Canada, too?
alanwbaker (author) says: Aug 11, 2012. 9:03 PM
Fair enough, blodefood. I've changed the wording. 8-)
suayres says: Aug 10, 2012. 11:44 AM
Terrific idea! Thanks for posting this. I didn't know there even was such a thing, and it's a brilliant concept.
kampusnosis says: Aug 10, 2012. 5:13 AM
I like it. Great idea.
jblessf says: Aug 9, 2012. 2:39 PM
Thank you for sharing with all of us. There is still faith in people.
kampusnosis says: Aug 10, 2012. 5:07 AM
I agree, amen.
Bosun Rick says: Aug 9, 2012. 9:10 PM
Just in case any of you can't ever seem to get around to doing this kind of project, remember there are "Free Libraries" in the Veterans Hospitals, and the Civilian Hospitals in nearly every city in the world. Just contact their Volunteer Services Office to donate books for our heroes and shut-ins. BOSUN RICK SEZ THANKS!
Ortzinator says: Aug 9, 2012. 3:18 PM
This would be great for an apartment building.
georogers says: Aug 9, 2012. 1:14 PM
There are two places that I've seen a similar deal.One is a library in Wells River Vt. where the librarian has an old greeting card rack on the Librarie's front porch wher she and others leave books for the taking.The other place that I've run into was a subway station in Porter Square in Cambridge Ma. wher coincidently another greeting card rack was left with a sign that said "Take A Book,Leave A Book".Good stuff!
rolltidehank says: Aug 9, 2012. 12:58 PM
This is also the first I've ever heard of it and I wish there was one close by. However, that might be the motivation that I need to make and manage my own! Thanks for the great project!
Wazzupdoc says: Aug 9, 2012. 12:31 PM
The whole concept is awesome. We have one inside the local commuter rail station. But it's only open from 0530-1230 while the station agent is there. I might make one to put on the OUTSIDE to service the "night-owls" and anyone else who travels when the station is closed for ticket sales.
How about a little solar pathlight installed so the LED lights up the Library's selections. A little pencil and note pad for comments would be fun too!
Mythbuster Kid says: Aug 8, 2012. 9:00 AM
Awsome I have tons of books and I am going to make one.
alanwbaker (author) says: Aug 8, 2012. 9:09 AM
Great--go Mythbuster Kid!
Mythbuster Kid says: Aug 8, 2012. 10:50 AM
Thanks!
rrkrose says: Aug 7, 2012. 9:29 PM
This is so cool! I have never heard of this program but it sounds super interesting. There isn't one in my area so maybe I can set one up? Anyway, this is a really cool instructable and the program is a great concept. :)
alanwbaker (author) says: Aug 7, 2012. 10:13 PM
Go for it! ;-)
lewisb42 says: Aug 7, 2012. 6:18 PM
A house in our neighborhood has one of these in their yard. It always makes me smile when I pass it on my walks.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
