Introduction: Little Lazies Monster Trio: Mummy, Cyclops and Zombie
Sculpey 111: Purple, White, Hot Pink, Granny Smith, Black, Just Orange
Super Slicer
Style and Detail Tools
Sculpey Acrylic roller
Sculpey Glossy Glaze
Clay dedicated pizza cutter
Getting Started
Do not use unbaked clay on unprotected furniture or finished surfaces. Start with clean hands and work surface area. Good work surfaces include wax paper, metal baking sheet, or disposable foil. Knead clay until soft and smooth. For best results, clean your hands in between colors. Shape clay, pressing pieces together firmly. Bake on a metal surface at 275 °F (130 °C) for 15 minutes per 1/4" (6 mm). For best baking results, use an oven thermometer. DO NOT USE MICROWAVE OVEN. DO NOT EXCEED THE ABOVE TEMPERATURE OR RECOMMENDED BAKING TIME. Wash hands after use. Baking should be completed by an adult.
Step 1: Step 1 - Creating the Mummy
Step 1 – Creating the Mummy
Mix together Purple and White by kneading with your hands until both colors are thoroughly mixed. If you prefer the Purple the original color remember to knead it so that it becomes pliable.
Step 2: Step 2 - Creating the Mummy
With your hands roll out 4 long teardrop shapes, 1 ¼” long, taped on one end and 3/8” in diameter at the wide end. Create the head which is approximately 1 ½” across and ¾” high and 5/8” wide. Create the body, a large teardrop that is about 1 ½” long. Set all the pieces aside.
Step 3: Step 3 - Creating the Mummy
Take a piece of White clay, knead it, and then roll it out thin using the acrylic roller.
Step 4: Step 4 - Creating the Mummy
With a clay dedicated pizza cutter, cut several strips of White clay. Set those aside as.
Step 5: Step 5 - Creating the Mummy
Take the head of the Mummy in your hand and use Sculpey Style and Detail Tool to press into the clay to make two round indents for the eyes.
Step 6: Step 6 - Creating the Mummy
Using the Needle Tool, push into clay and make a mouth-shaped indention.
Step 7: Step 7 - Creating the Mummy
Mix the White and Pink clay to make a Light Pink color and form it into a tongue shape, a flattened circle with one end cut off. Push the tongue inside the indention for the mouth and add a small line on top of the tongue using the needle tool.
Step 8: Step 8 - Creating the Mummy
Form 2 small balls and insert into the eye sockets. Using Pink clay add a small, oval nose between the eyes. Using small flattened balls of Orange and Black clay add an iris and pupil on the eyes. Now set the Mummy head aside.
Step 9: Step 9 - Creating the Mummy
Step 10: Step 10 - Creating the Mummy
Take the Mummy body and the Mummy head and attach to each other by pushing them together and smoothing gently. Also take the White clay stripes and start wrapping up the body!
Step 11: Step 11 - Creating the Mummy
Add bunny-like ears by making tear-drop shaped clay and pressing into holes made with a Pointed tool on top of the head.
Step 12: Step 12 - Creating the Mummy
Continue wrapping up the Mummy - do this randomly and have fun with it, doesn't have to be perfect!
Step 13: Step 13 - Creating the Mummy
Add the Mummy arms and legs to the body - gently smooth them onto the body. Add small details, like a little Pink belly button on the stomach. The belly button is a tiny ball of clay pushed on the tummy with the needle tool.
Bake as directed above. Once cool, add Sculpey Glaze anywhere you would like (2 coats), also using White Tempera paint and a small paint-brush, add a white dot on the eyes - this gives it life. Now you're done with the Mummy!
Step 14: Step 1 - Creating the Cyclops
Mix the Orange and White clay by kneading with your hands until both colors are thoroughly mixed. If you would like to keep the Orange the original color remember to knead it so that it becomes pliable.
Step 15: Step 2 - Creating the Cyclops
Step 16: Step 3 - Creating the Cyclops
Take the Cyclops head and using the largest Style and Detail tool press a large indent for the one big eye!
Step 17: Step 4 - Creating the Cyclops
Add a White eyeball. Using small flattened ball of Orange and one of Black clay add an iris and pupil to the eyeball. With Orange clay, make an eyelid over the eye, this can be altered to make him look happy, sad, angry, confused - any expression you wish! Start with a thin Orange half moon. Add a mouth by making a small round ball placing it on the head and pressing on with the smallest Style and Detail tool. Don't forget the mouth too, just a round piece of Orange clay pressed onto the face, then a small hole pushed into the center.
Step 18: Step 5 - Creating the Cyclops
Take the head, body, and all 4 limbs and gently press and smooth to attach them all together.
Step 19: Step 6 - Creating the Cyclops
Take Pink clay and make a thin oval shape for the belly - place on the body of the Cyclops.
Step 20: Step 7 - Creating the Cyclops
Using a thin wire or clay knife, make indents on the belly to look like stripes.
Step 21: Step 8 - Creating the Cyclops
Add the horns by taking Orange clay in a small circle pressed onto the head, then making a hole with a Pointed Tool.
Step 22: Step 9 - Creating the Cyclops
Make horn shapes out of the Purple clay and insert those into the holes you just made!
Step 23: Step 10 - Creating the Cyclops
Using Pink clay make a "tuft of hair" for the top of the Cyclops head - make a tear drop shape then cut lines into it with a clay knife. Make a hole on top of the head and push the Pink "hair" into the hole.
Step 24: Step 11 - Creating the Cyclops
Add small details like polka-dots on the Cyclops in any colors and where ever you wish to place them! Have fun.
Step 25: Step 12 - Creating the Cyclops
Bake as directed above. Once cool, add Sculpey Glaze anywhere you would like, also using White Tempera paint and a small paint-brush, add a white dot on the eye - this gives it life. Now you're done with the Cyclops.
Step 26: Step 1 - Creating the Zombie
Mix together Granny Smith and White Sculpey III by kneading with your hands until both colors are thoroughly mixed. OR keep the Granny Smith clay the original color, but remember to knead it so that it becomes pliable.
Step 27: Step 2 - Creating the Zombie
Step 28: Step 3 - Creating the Zombie
Take the Zombie head and with a large Ball Tool form a hole (or cavity) for the brain. Then set that aside.
Step 29: Step 4 - Creating the Zombie
Take Pink clay and form a peanut shape for the first part of the brain.
Step 30: Step 5 - Creating the Zombie
Take Pink clay and roll out into a long coil.
Step 31: Step 6 - Creating the Zombie
Grab the peanut shaped brain and the coil - take the coil and in a zig-zag motion place it on the brain until the peanut-shape is covered.
Step 32: Step 7 - Creating the Zombie
The brain is finished, so take the Zombie head and place the brain into the cavity.
Step 33: Step 8 - Creating the Zombie
With a small Ball Tool, push into head to make 2 eye indents.
Step 34: Step 9 - Creating the Zombie
Add White clay eyes with iris and Black pupil, then attach the head and body. While you have that in your
hand, take the large Ball Tool and press into the body to make a large hole.
Step 35: Step 10 - Creating the Zombie
The hole you just made is for the guts! Make these almost the same way as the brain, but just on a flat, round piece of Pink clay.
Step 36: Step 11 - Creating the Zombie
Take one of the legs, cut off the end of it with a clay knife, then add a piece of pink clay to the end.
Step 37: Step 12 - Creating the Zombie
Make a hole on the end of the pink part of the leg. Take White rolled clay, cut it, and add a "bone" to the end of the leg by pressing it into the hole.
Step 38: Step 13 - Creating the Zombie
Take the Zombie head, body, arms, and legs and gently attach them all together by smoothing together.
Step 39: Step 14 - Creating the Zombie
Lastly, using a Pointed tool, indent a line for the mouth and add small pieces of Green clay for "stitches". Add last little details to make it even cuter - a horn/ear, dots, and a heart!
Step 40: Step 15 - Creating the Zombie
Bake as directed above. Once cool, add Sculpey Glaze anywhere you would like, also using White Tempera paint and a small paint-brush, add a white dot on the eyes - this gives it life. Now you're done with the Zombie!
