Little Red Wagon Bench
1,884
64
4
Published
Introduction: Little Red Wagon Bench
About: To see more of my work, be it wood, painting, or other stuff, find me on Instagram at AMATEURHOUR87.
I came across an old little red wagon (almost identical to a radio flyer wagon) outside a friend's house and knew I could make something cool out of it. After weighing my options I decided to make a small bench out of it using reclaimed pallet wood for a top. This project is relatively easy and requires only a few tools and supplies.
Materials:
Scrap Pallet Wood (because the pieces needed are relatively small, its easy to find enough lengths from salvaged pallets)
Scrap Furring Strips (I had some left over furring strips that worked well to hold the bench top inside the wagon)
Table Legs and Fixtures (I bought these from a big box store but they could easily be found from a scrapped table)
Red Spray Paint / Primer
Dark Stain (I used Ebony Minwax)
Quick drying Polyurethane
Small Screws, Bolts and Lag Bolts (I used 1/2 inch and 3/4 inch self driving screws and lag bolts)
Wood Glue
Tools:
Saw (I used a miter saw and a jigsaw)
Power Drill
Abrasive Pads
Paint Brushes
Shot Blaster (Optional but very helpful)
Step 1: Stripping the Paint
The wagon had a lot of old and chipped paint on it and quite a few rust spots. I used abrasive pads attached to a power drill to remove some of the paint but decided that it would be a better use of time to take it to a local shot blasting facility and strip the paint there.
Step 2: Attach Supports and Leg Plates
I attached the furring strips to the inside of the wagon using small 1/2 inch lag bolts making sure that the strips were low enough to accommodate the bench top (making it close to flush with the top of the bench) . The screws that came with the leg plates would not work with the thin metal so I drilled holes the same diameter of the plates and bolted them to the wagon.
Step 3: Pallet Wood Top
Using a miter saw I cut the pallet wood into short planks and attached them to three sections of furring strips using 3/4 inch screws and wood glue, clamping each plank until the wood glue was dry (the furring strips should be placed far enough away from the edges to allow the bench top to rest on the strips attached to the wagon). The two planks at either end of the bench top needed round corners to fit into the wagon so I used a jigsaw to cut them.
Step 4: Painting, Staining, Finishing
I primed the wagon and then spray painted it red. I used two cans to coat the inside and outside of the wagon a few times, giving it a nice glossy finish. The wooden legs I stained dark using Ebony Minwax and the bench top I coated in a quick drying polyurethane. I used three coats of the polyurethane to bring out the wood's natural beauty and leave it with a shine comparable to the spray painted wagon.
Step 5: All Done!
After screwing in the legs and setting the bench top into the wagon its all done (the top is removable to allow for storage underneath). I hope you enjoyed this Instructable and I hope you build a little red wagon bench of your very own! Feel free to vote for me in the wood contest!
Backyard Contest 2016
Runner Up in the
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    4 Comments
    I love this project, as well as your recycling! Nice job.
    What a neat idea! Thanks for sharing your project with the community. :-)
