Little Sister Adam Syringe
11,906
92
4
Published
Introduction: Little Sister Adam Syringe
About: I am a graduate from Savannah College of Art and Design. With a passion for making things I always go into a project with the hopes that I come out of it with a better way of how to do something. I do repli...
Made to resemble the Adam Syringe's that the Little Sister's in the video game Bioshock use. I started playing the games and became enamored with the world and all the hodgepodge items throughout it. Ive seen many versions of this build but I decided to try my hand at it.
Step 1: Gas Pump
To begin with i ordered an antique gas pump from ebay for pretty cheap. I did very little modification to it since its pretty much how it should be. The only real modification i did to it was to drill a hole in the top metal piece in order to attach the "adam" jar.
Step 2: Jar
The jar i used was a salad dressing jar that i had finished. The only thing i did to the jar was drill a hole in the lid to attach to the gas pump.  The "adam" is mens shampoo with some red Smooth-on So-Strong pigment mixed into it.
Step 3: Needle
The needle is a .5" diameter rod that i hand forged to a point.
Step 4: Cap Piece
The cap piece where the little sisters "drink the adam" is turned from two pieces of maple with a baby bottle rubber sucker thing sandwiched between them to hold it in. I simply glued it onto the jar at the end.
Step 5: Painting
For paint i wanted to age the piece to make it look like an antique brass/bronze instead of the silver metal it was originally, so i used gold hammered spray paint with some spritzing of black to give it that weathered look.
  • Stick It! Contest
    Stick It! Contest
  • Oil Contest
    Oil Contest
  • Water Contest
    Water Contest
4 Discussions
I have a question: if you bring this thing to, say, a convention, are they going to let you in?
Awesome!
Only problem.. If somebody is using this at a Cosplay event.. You're not making it in there.. You can't have any sort of weapons made of metal.. which.. Is understandable.
