loading
Is there any way to print these files out to correct size and cut by hand?
the wiring diagram is suuuper confusing, could you make another one
This looks heavy duty! Could you give me the exact size of the templates?
Here's what I built with this kit. What would you make? <br>http://youtu.be/7xwPYwl00O0?hd=1
what is the wiring diagram for an arduino instead of an picaxe
what is the wiring diagram for an arduino instead of a picaxe <br>
what is the power source for this thing i would like to know please as i am thinking of making it. <br>
bonjour le plan et 100% <br>merci
superbe r&Atilde;&copy;alisation
Where can I find 4mm Acrylic sheet?
Nice! <br>I'm going to follow you, because i like this! <br>Give it an X-Bee!
no code?
I bought most of the parts with the exception of the gearbox and range finder&hellip; I did have a problem with the tank&rsquo;s tracks&hellip; exactly like the ones pictured.. . The rubber shriveled up and broke! I don&rsquo;t know if it was from the batch of rubber they used for my tracks or unlucky AC in the summer and heat in the winter in my project room&hellip; Has anyone else had a problem with the rubber tracks? And does anyone know of a replacement &ldquo;metal&rdquo; or swivel plastic tracks that would fit this kit??
I left one of my robots in the garage over the summer, and I had the same thing happen. Your tracks were probably exposed to too much heat at some point. <br> <br>If they were new out of the box, you should complain to the place you bought them.
I may have to just r-order them, I am looking into micro servos right now and I got a XRF wireless UART serial data module XBee shape arduino from the UK. I am also looking into alt wheels/tracks etc etc.. the chassis is pretty sweet I have to add..
Cool. Post back if you get this chassis working with a different set of tracks, or with micro servos as the drive instead of the Tamiya gearbox.
Hey there. I have posted a nice review of this product on my blog. <br>http://ignoblegnome.blogs pot.com/2012/02/introduction-last-september.html
About how much does it cost and would you sell one<br>
I found the only really good place for a battery pack was the lower deck, underneath the servo. This only works with a mini servo, as the standard servo gets in the way. I used a 3xAA battery holder, and it fits just fine. <br> <br>I may use the new-ish 1.6V NiZn rechargeable batteries with this robot. They start fully charged at 1.8V, so they should last a while.
I ran into some trouble on this step. You have to assemble the parts in the right order, or you'll wind up taking it apart and re-doing it. <br> <br>I suggest the following order: <br>1) Attach the left side to the bottom deck. <br>2) Put the left motor shaft through the left side. <br>3) Slide the right side over the right motor shaft and attach to the bottom deck. <br>4) Attach the servo to the top deck. <br>5) Put the top deck in place, and attach the motor first, then the deck screws.
About This Instructable
47,933views
108favorites
License:
Bio: part time robot designer :-)
More by propellerheadgeek:High precision table alignment on your laser cutter made easy! Make the tool. I love you Penguin - Made for my wife :-) lasercut 'Little Tank' Robot Arduino/Picaxe/Tamiya platform
Add instructable to:
