LittleBits LazerTag Sensors
10,001
204
6
Published
Introduction: LittleBits LazerTag Sensors
Who doesn't like Lazer Tag, right? .
In this Instructable we're going to show you how to use LittleBits and an Altoid tin to make a flashlight tag sensor that will buzz when someone "tags" you (by shining a flashlight on you). Now you'll know for sure when you've tagged someone and it's their turn to be it. We usually play this in the yard but have included a quick little video here that we shot in the house to show you how it works.
They are super fun to play with and after a couple holes are drilled a kid can build the whole thing on their own.
Step 1: What You'll Need
9 Volt Battery
Altoids Tin
Spraypaint (whatever color you want)
Flash Light
Cel Phone Arm Holder
Arm Band Cel Phone Holder (not pictured here)
LITTLEBITS
1 - Power Bit
1 - Light Trigger Bit
2 - Wire Bits
1 - Buzzer Bit
Step 2: Connect Your Littlebits
Connect your bits like we've shown here. They stick together with magnets so it's really easy. Be sure to have your Light Sensor Bit set on "light" mode so that it allows power to travel through when there is light shining on it. That way it will make the buzzer go off when you shine a flashlight on it.
Step 3: Drill Holes in the Altoids Tin for Light Sensor and Buzzer
Now it's time to drill a couple holes.
First use a 1/2 inch bit to drill a hole in the back of the tin. This will be the hole that revealed the light sensor. The center of the hole should be 3/4 inch from the left side of the tin and 1 1/4 inch from the top of the tin.
Next you'll want to drill some holes to allow for sound from the buzzer to escape the tin so that people hitting it with their flashlight from far away can still hear it go off. These can be with any small drill bit - we used a 1/16th inch bit. By using an awl to start each hole you can make the drilling a bit easier and more safe. It keeps the bit from moving around while you're trying to keep it steady on the corner of the tin.
Step 4: Sand and Paint Altoids Tin
This part is pretty simple - just sand the whole tin to roughen it up so that the paint will stick and line the inside of the tin with tape to keep it clean so that your LittleBits don't get dirty. Then you can spray it with whatever color you'd like. We did two different colors on 2 tins to make a set with some orange and white that we had in the shop.
Step 5: Insert LittleBits Into Tin
Two very important notes:
1 - The LittleBits and battery fit perfectly into the tin but you have to get things just right in order to actually get the lid to close and the sensor to line up. Don't force it if the lid doesn't close as you could hurt the LittleBits. You may have to mess around a bit with getting all the wires pushed down into place but once things are in their right places the lid will close easily.
2 - the LittleBits Power Bit has a small red light that turns on whenever you have the power turned on. This will set off our light sensor which is bad because we want our flashlights to do that. So you need to cover the light with something so that it doesn't set off your sensor from the inside. We've used a small bit of sticky tack to cover ours in this tutorial but we've used electrical tape before as well and it worked just fine.
Step 6: Add Graphics to Tin
By cutting up some old vinyl stickers we made a couple lightning bolt graphics that added a little street creed to our new sensors.
Step 7: Insert Into Arm Band
All that's left is to insert each sensor into an arm band cel phone holder, grab a flashlight and get out in the yard.
Have fun - thanks for reading.
Supercharged Contest
Third Prize in the
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    6 Comments
    NEED...TO...MAKE...THIS. but I don't littlebits :(
    Awesome!
    Very intuitive thinking!
    Cool. Something I might try in some of my spare time.
    Hey KRA5H -
    Thanks for the comment. I've seen your Instructable before and loved the idea for the alternate power source. I also loved seeing LittleBits and and Erector set being used together. Nice stuff.
    I've entered our Instructable into the contest and am just waiting for it to be approved - i see that you're entered as well. Good luck.
    keep making,
    - Tim + family
    I'll vote for your Instructable if you vote for mine, lol.
    Cool idea for littleBits. You should enter your Instructable in the Supercharged Contest.
    To save from having to keep buying 9 volt batteries take a look at my littleBits Instructable:
    https://www.instructables.com/id/littleBits-Sample-...
    I demonstrate how to power your littleBits projects with an adjustable power supply wallwart (for use with littleBits projects you aren't going to wear or carry on your person).
