Introduction: Littlebits Alarm
Picture of Littlebits Alarm
Hejo! Today I'm going to show you how to build a burglar alarm using LittleBits. In case you didn't know, Littlebits is a system of interlocking electronics modules that you can use to create a lot of stuff with. They are easy to use and great for beginners and prototypes alike.
Step 1: Parts
For this instructable, you will need these bits:
  1. Power
  2. Slider
  3. Buzzer
  4. Sound Sensor
  5. Pulse
  6. 3 way connector
  7. Latch
  8. Motion Detector
  9. Any LED Bit
  10. Cloudbit
Step 2: Setting Up Power
Picture of Setting Up Power
As I said earlier LittleBits are easy to use and fun to prototype with. This is the first part of the bit-build; the power. After the power bit, you should add any sensor and the latch proceeding the sensor. After the Latch bit, add the #-way connector( Use picture).
Step 3: Adding the Buzzers and Light Makers!
Picture of Adding the Buzzers and Light Makers!
So now that you have the power setup, it is time to add the actuators to the 3-way connector bit. I chose the arrangement shown in the picture above, but its up to you to mish-mash the actuators together in your own way. Note: I used the Cloudbit in my alarm. If you will seriously use this alarm to protect your valuables, I strongly recommend using the Cloudbit. it can be configured in a way so that it can transmit messages to your laptop. It would notify you if something was up, and would be a good addition to any alarm.
About This Instructable
408views
9favorites
More by DerpyCyclops:Mini Hovercraft W/ Arduino NanoUSB Mouse W/ Circuit PlaygroundIlluminati Backlight-Lamp
Add instructable to:
