Live Edge Tasting Flight
1,401
27
11
Published
Introduction: Live Edge Tasting Flight
About: I am a work in progress, but I'm working on it. No rush.
I'm a bit obsessed with producing projects to develop my basement bar as well as my friends'. I don't know why I chose the design of this rather than a sampler beer tasting paddle or a tray. This is just how this particular piece of wood would match with it's destination best.
Please remember to wear whatever safety gear is needed.
Thanks, enjoy.
Garwulff
Step 1: Choose Your Boards.
I am always trying to use materials I feel connected to. I like to use trees I've dropped or friends trees I've helped with. I knew someone who had one of the very last 150+ year old Elm trees. It was a beautiful giant but it was dying and in danger of falling and cutting neighborhood houses in half.
I kept a couple logs and had them cut into boards. I knew this flight was for a friend's bar. The bar has a live edge so I picked a board with beautiful straight grain a nice live edge and a trench a grub had eaten through.
Step 2: Cut to Dimensions
Rip one edge of the board straight (the live edge you don't want to display) and cross cut board to length.
Step 3: Resaw and Plane
Resaw the board. I wanted the top to be a little thinner than the bottom, so I resawed it about one third and two thirds. Then I planed the two boards.
Step 4: Drill/Route Holes
The drill bits I have weren't exactly the right diameter for the tasting glasses to sit correctly. I drilled the holes for the glasses to the closest size I could. Next I used the circle template that I made out of Masonite and used it to guide a flush trim bit on my router. This got me to the exact size I needed.
Repeat this as many times as glasses you need in your tasting flight.
Step 5: Doweling
Mark the locations of the support dowels. Drill through the bottom board and just barely into the top board while both are clamped together. This will make sure that the holes line up, the boards line up and the dowels are plumb.
I cut my dowels down from a 1/2" oak dowel that I had laying around. Then I glued the dowels into the bottom board flush with the underside of the board.
Step 6: Sand, Sand, Tack, Lacquer, Lacquer, Sand, Lacquer
Sand all milled surfaces with 150 grit.
Sand all milled surfaces with 220 grit.
Wipe everything down with a tack cloth or a lint free rag and mineral spirits.
Spray lacquer.
Spray lacquer.
Spray lacquer.
Sand all milled surfaces with 300 grit
Spray lacquer one final time.
Step 7: Assemble and Attach Feet
Do the final glue up, attaching the top to the support dowels.
Drill pilot holes for the feet. Screw feet into the bottom of the dowels to cover them up.
Step 8: Taste and Repeat
Pour beer. Put the glasses in the flight. Taste and repeat often with friends and family!
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    11 Comments
    Nice job on the Beer Flight here is a link explaining that "flight" is actually the correct term.
    http://www.truebeer.com/What-is-a-Beer-Flight_b_8.html
    WTF is a live edge tasting flight? I came here wondering what it was, only to see that you created a beer glass tasting tray. Gimme a break and call it what it is so that people can see what they're clicking. Please!
    Live edge refers to the natural edge of the wood. I.E. it's not a square board edge. By the way, Instructables has a "be nice" policy with regards to comments. Have a great day!
    Of course. I'm aware of the be nice policy. I was a little frustrated by your vague title. I'm sure you have an explanation for 'Tasting Flight' too. I guess your take on drinking beer is different from mine. Cheers!
    I'm sorry, it's not my Instructable. A "tasting flight" is a small group of brewery samples on a board.
    Again, you are doing a better job of explaining my stuff than I would have. Thanks much.
    -Chreers
    Thanks, couldn't have said it better myself.
    I should have done a better job and thought about the title more. To me it made sense but I guess I didn't realize it was vague.
    Thanks for being passionate enough about it to help me out.
    I like the project, the looks of the bar and especially the beautifull wall boards. Gives a cottage feel to the bar.
    Thanks, functionaldesign.
    And I agree. My neighbor did an amazing job on his basement bar. It is beautiful. I hope the beer tasting board is at home there. And I hope it gets a lot of use.
