Lm386 Multi Purpose Amp
3,157
76
13
Published
Introduction: Lm386 Multi Purpose Amp
About: A teenager fit for doing nothing but likes to do everything he likes doing :)
The Lm386 milti purpose amp, can be used with audio devices, guitars etc :) ENJOY !!!! and it works great :P
WARNING - do not connect to 12v dc supply, the lm386 and the 100uF cap may blow up !!!
HAPPENED WITH ME :p
Step 1: Parts U Need !!
  1. LM386 IC
  2. 10K POT
  3. 220uF CAP
  4. 10uF CAP
  5. 100uF CAP
  6. 0.047uF CAP
  7. AUDIO MALE FEMALE JACKS AS PER REQUIREMENT !!
  8. AUDIO CABLE
Step 2: SCHEMATICS
follow the given schematics first on a breadboard to avoid any inconvenience and later put it on a circuit or purf board and solder.
Step 3: SPEAKERS
  1. I've arranged the speakers from a junk shop nearby.
  2. they are loud enough but after a certain amount of amplification they start to distort.
  3. it would be better if you use bigger and more powerful speaker.
HAVE FUN AND LEAVE YOUR FEED BACK :)
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    13 Comments
    Thanks Mate!
    I hope to try it out this weekend.
    BTW, Was "Feedback" used a deliberate play on words? :)
    didn't get u human !!! !! ??
    u made it or picked it up from somewhere ??
    That image is a proper schematic done from your hand drawn schematic. I have made a similar build but used extra filtering capacitors between +VCC and ground because I powered mine from a wall supply and was getting noise. If you wanted to power it with a wall adapter, you only need to add 100uF and a 100nF caps in parallel between +VCC and GND to filter noise. Here is the schematic I used:
    hi friend, i wanted to make a simple mic - speaker system but was not able to because of missing amplifier than u for helping me
    Thank you human !!! Just saw the mistake :p
    to be clear this is mono correct? not stereo. 3 speakers are shown suggesting its a 2.1 system with left and right channels with bass. Unless somehow a lm386 is capable of this i am co fused at the use of 3 speakers. If it is capable please explain.
    They r all in parallel , i just connected as many speakers as i had :p so nothing to worry about and yes it s a mone :)
