Location and Food Clock
3,405
55
9
Posted
Introduction: Location and Food Clock
IoT Builders Contest
Second Prize in the
I created the location-food clock as a way to notify my mom about where I am and whether or not I have eaten the appropriate meals for the day. It uses the location from my smartphone and turns the clock hands to one of three positions: Home, School or Elsewhere. The hands of the clock have three lights accounting for the three meals of the day. Whenever I have a meal, I press a button on my phone (using the IFTTT app) and the appropriate lamp lights up. At the end of the day, if all three lights are on, my mom would be relieved and happy to know that I have had food throughout the day. At midnight (my local time), the lights would all turn off. This clock was created with just my data, but in the future, I plan to add more hands for other members of my family as well. I have wanted to make something like this since I was about 18 years old and my mom would call me twice a day to ask if I had eaten and later on when I started working, my dad would ask me if I was at work or had already left. I wish I had this clock then!
The project was also slightly inspired by the Weasley clock from the Harry Potter world.
Step 1: Things Required
Adafruit Feather HUZZAH with ESP8266 WiFi
Servo motor
RGBW Neopixel LEDs - 3
Rapid Set Cement All - 10 lb pack (optional)
Acrylic paints (colours of your choice)
Takeaway containers of two different sizes
Wires
Soldering iron and solder
An account on Adafruit IO
An account on IFTTT
Step 2: Adafruit IO and IFTTT
Create an account on Adafruit IO. Once you have created an account, go to your feeds and create a new feed called "location". The Huzzah Feather board gets its data from this feed.
The next step is to create an account on IFTTT. Once you have an account on IFTTT, search for and connect to the Android/iOS location channel and Adafruit channel. Then create these four applets :
1. If you enter the location of your work/school, send the data to the "location" feed created on Adafruit IO with the value "School" or "Work".
2. If you exit the location of your school/work, send the data to the "location" feed created on Adafruit IO with the value "Travelling" or "Elsewhere".
3. If you enter the location of your home, send the data to the "location" feed created on Adafruit IO with the value "Home".
4. If you exit the location of your home, send the data to the "location" feed created on Adafruit IO with the value "Travelling" or "Elsewhere".
Once this has been setup, the "location" feed will keep updating every time you enter and exit your home and school/work.
Step 3: Connecting the Circuits
Start by setting up the Huzzah board by following the instructions on this page.
Next, add the Adafruit IO package to Arduino IDE by following this process.
Once the board is setup, connect the neopixels and the servo motor to the circuit using the circuit diagram below. First test the circuit and the code on a breadboard before soldering all the connections. The Arduino Uno board with my breadboard circuit is completely unnecessary, it is just attached to my breadboard, hence, it is in the picture.
I have also attached the sketch I used for the project below which you can download and use--just remember to input your Wifi name and password, and the AIO username and key in the code with your own.
Step 4: The Clock
The body can be made with essentially anything and in any form that you want. For this project, I used plastic containers and cement to cast the shape I wanted. I started by first preparing the mold. I cut holes at the bottom of the two containers and placed a wood dowel to hold them apart. I also used a flat foam core sheet, cut in a circular shape, to make the bottom of the bigger container flat, since I wanted to have a smooth flat surface for my clock face. Using foam core was a mistake, since it stuck to the cement once it set. But I was able to scrub it off using water and a scrubber.
Once the mold was ready, I greased all sides of the containers with some oil. Then, following the directions on the cement package, I mixed 1 part water with roughly 3.5 parts of cement, mixing slowly to avoid air bubbles and preventing lumps. The package says to mix 1 part water to 4 parts cement, but I found that 3-3.5 parts of cement were sufficient. I should have added lesser cement to ensure a proper flow of cement everywhere. But my mixture was too thick and I ended up having a large uneven hole on the top surface which I had to fill in later. After mixing the cement with water, pour evenly in the mold and let it set for about 15-20 minutes. It dries and hardens differently based on the temperature in the room, so give it sufficient time to set and dry and then it becomes really hard.
I made the hand of the clock using a scrap strip of wood. I cut it to the required length, rounded off the edges and drilled three holes for the LEDs.
All the parts are now ready for assembly.
Step 5: Assembly
I basically just taped all the parts in place. Then I put the three Neopixels on the three holes on the clock arm and get the wires neatly tucked under the arm and through the hole in the middle of the clock face. Then I glued the clock arm to the shaft coming from the motor.
It is now ready to be used! Hang it up on the wall in your mom's house :)
Step 6: Next Steps
If I were to take this project further, I would add more hands on the clock for other members of my family. My problem with this currently is that I would need a different servo motor to drive each new hand and don't know how I would do that.
Please leave any feedback or suggestions in the comments below!
And also share your versions of the clock and what other applications can this have.
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    9 Comments
    I made a location based clock similar to this. Great job and feel free to check out mine!
    That is amazing. I know that my mother would love to have one of these. One thing to consider is that you could make the indicators all LEDs or a video screen. So for instance you could have a different color LED for each family member, and mount one at each location. Then the food chart could be a little LED bar graph to the side.
    Hey, thank you for your great suggestions! That's the wonderful thing about this is that you can make it with lights or displays or any other way, whatever suits your budget and purpose. For my project, I wanted something more analog since we already have so many screens in our life, hence I chose to go with the clock hand metaphor. Thank you for checking out my project!
    This is really cool!! Great work!
    Thank you for your encouraging words and for checking out my project!
    Real life Weasley family clock from Harry Potter.Well done!
    Thank you so much!
    My mom would love this. Great idea. Every conversation as a kid would always start the same way. "Did you eat? What did you eat? Did you eat it all?"
    Exactly! I am glad other people can relate to this too. I hope you build one yourself, and share your project if you do. Thanks for checking out my work!
