Loft bed with built in bookshelf and pegboard
 by awarden
Featured
Step 4: Base frame
The base frame is made from 2 stringers of 90x35 pine, with 42x19 supports along the inside of each length.  90x19 pine planks were cut, glued and nailed between the stringers.  at the head end, the planks were left off and I made a small insert to fit inside the top of the bookshelf, to allow for easier assembly.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
