Log Bench
Published
Introduction: Log Bench
Custom log bench
Step 1: Cut a Large Log in Half, Long Ways
this log weight about 500lbs, had to use my truck pull it out and then a tractor for lifting.
Step 2: Smooth Out the Surface
I used a hand planer and belt sander to smooth out the top.
Step 3: Burn the Design
Draw your pattern and then burn it with a wood burning pen, this log is oak and it took a long time to burn it, probably about 3.5-4 hrs.
Step 4: Seal the Log
use an outdoor grade wood sealer to protect it from the weather.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    5 Comments
    Do you seal only the bench top or the rest of the logs (bark) as well?
    I sealed everything, multiple coats, just to prevent rot. And as the wood dries , some small cracks will pop up. Give a few days between coats as the wood may absorb some of the sealer.
    Curious as to how this is holding up? i have just cut a log in attempt to make a similar bench but m undecided if i should leave the bark on, i have read a lot of postings that suggest it will habour bugs and probably end up falling off anyway... hows it holding up for you?
    I just now made 2 log benches i but did not see this until I was finished.
    did you notch the bottom of the seat section of the log?
