Logic Probe W/display
Published
Introduction: Logic Probe W/display
About: I'm engineer and like to design electronic and programming things with Arduino hardware.
This project is equipped with 5 Not Gates, 1 transistor, 8 resistors, and 1 Common Anode Display. The Logic Probe w/display is a project for identifying Zero (0) or Low, One (1) or High, or Pulse. For Zero, you will see illuminated the upper side of the display by simulating a "0" (Zero). For One, you will see illuminated the rest of display for forming a "P" without illuminating the upper side of the display by simulating a "1"(1). Finally, for a Pulse, you will see illuminated the display by forming a "P"(Pulse). And so you can detect "0's", "1's", and Pulses.
Step 1: List of Materials
The list of materials is the following:
1 Prototype Board
1 Green Display CA
1 7404
1 IC-socket 14-pin
1 Transistor 2N3904
5 Resistors of 330 Ohm
1 Resistor of 470 Ohm
1 Resistor of 10K Ohm
1 Resistor of 1K Ohm
1 +5V Standard Regulator
2 Electrolytic Capacitors of 47 microF, 50V
1 Battery Clip, For 9 Volt
1 Test Leads, Banana, 42 inches, 1 Red, 1 Black
1 Binding Post, Breadboard, Screw, Type, Chassis Mount, 1 Black, 1 Red
9 V Battery is not included
Required tools or supplies:
Soldering iron
Solder
Wire stripper and cutter
Needle nose pliers
1 Jumper Wire Kit (Radio Shack Part # 276-173)
Step 2: Install the Components
Step 3: Complete Your Project
9 Volt Battery is not included
Step 4: Logic Probe W/display in Action
Probe Digital Circuits
The sequence of pictures:
Low "0"
High "1"
Pulse "P"
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    32 Comments
    This project can also be seen in Amazon webpage at:
    https://www.amazon.com/JAMECO-KITPRO-Logic-Probe-Display/dp/B00C9NWOCS/ref=sr_1_fkmr1_1?ie=UTF8&qid=1481318835&sr=8-1-fkmr1&keywords=Logic+Probe+w%2Fdisplay%2C+jameco+electronics
    This project can also be seen in Jameco Electronics at:
    http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&productId=2171532&catalogId=10001&CID=CLO
    LEATHERWORKING classes are now free in this site.
    BREAD classes are now free in this site.
    PHOTOGRAPHY classes are now free in this site.
    CANNING PRESERVING classes are now free in this site.
    WOODWORKING classes are now free in this site.
    GLUE classes are now free in this site.
    CONCRETE classes are now free in this site.
    MEAT classes are now free in this site.
    WEARABLE ELECTRONICS classes are now free in this site.
    RASPBERRY PI classes are now free in this site.
    LASER CUTTING classes are now free in this site.
    LAMPS classes are now free in this site.
    CNC classes are now free in this site.
    3D PRINTING classes are now free in this site.
    Robots classes are now free in this site.
    Electronic classes are now free in this site.
    Arduino classes are now free in this site.
    LEDS & LIGHTING classes are now free in this site.
