Items needed:
Drill-Use a drill with at least 1000 rpms. A slower drill will give you uneven sanding/buffing
Drill bits-I used an 1/8th inch bit because it was sitting on the work table
LEDs-I salvaged some from a rope light
Mutli-meter
Heat Shrink tubing
Hot Glue
Soldering iron/electrical solder/flux
Wire-I used some salvaged outdoor, solid, 20ish gauge phone line wire (solid wire holds its shape)
resistors-dependent on LED voltage
Clear acrylic-thickness is completely personal preference. I used 1/8" as I had it handy. You can mismatch thicknesses or stack the acrylic to give you different looks.
Marker
Bolt and nut (I used a 1/4 20)
Rotary tool with a sanding bit
(As all my past/future instrucables will go, I finished the project before I decided to write a tutorial, so some of the steps are already finished in the pictures.)
Remove these ads by
Signing UpStep 1Getting to the guts
To start:
You will need to cut into the label on the bottom of the dock to find the 3 hidden screws.
Once the screws are removed, open up the dock. Inside the dock you will see two more screws, remove them.
The next part is a bit tricky. You will have to push in the two metal contacts on the top of the dock while you pull down the board on the inside.
comment
Add Comment
sook
says:
Add Comment
