loading
Picture of Long Distance Laser listening device
the following project will show how you can use a laser pointer to hear noises from hundreds of feet away (the distance will be relative to the strength of the laser).
Step 1: Materials
Picture of Materials
We need
1. a laser pointer
2. a old pair of headphones (mic cable with stripped ends)
3. cadmium sulfide photocell (avaible at radioshacks)
4. 2 Tripods
5. A computer with audio recording software
Step 2: Connect the Photocell to the Mic. cable
Picture of Connect the Photocell to the Mic. cable
twist the photocell wires around the stripped ends of the mic cables
Step 3: Testing the photocell
Picture of Testing the photocell
1.first plug in the mic cable into the laptop.
2.notice the audio meter when the light hits the cell.
Step 4: Setting the position of the photocell and The Laser.
Picture of Setting the position of the photocell and The Laser.
1.Attach The Photocell To Tripod #1
2.Set Laser To Tripod #2
Step 5: The Important Part.
Picture of The Important Part.
1.Adjust Laser Until Reflected Beam Hits Photocell.
2.let the rays of laser reflect on a mirror or a glass to hit the photocell.
3.Now just hit record and then u can spy on them
Step 6: Instructions on the listening device
Picture of Instructions on the listening device
1.Find a room with a window you'd like to spy on, and aim the laser at the window at an angle.
2.Determine where the laser reflects, and situate your photocell so the reflected beam hits the front of the cell.
3.Hit record and listen!
4.Any noise from inside the room will cause the window to vibrate, which will get picked up by the laser and photocell. You might have to process the raw input to remove unwanted noise and isolate the voices.
now here is a picture how does it work.
macboy98 (author) 4 years ago
pls vote for me in the wicked laser contest
bossmansam4 years ago
couldn't you do it with an IR laser (provided you have the tools necessary to align it with the photocell)
You can if you have the sender and receiver. It's be better because IR is invisible to the naked eye.
stebanqui1 year ago
Laser photophone, you must use an audio amplifier to replace the pc too.
sjroth2 years ago
http://www.youtube.com/watch?v=iI8w2s05sd8
Found the video you got this from. Congratulations, you know how to take screenshots.
robot13984 years ago
did you really make it
macboy98 (author)  robot13984 years ago
yup!
i think you did not take those pics
you just copyed and pasted here from google
no
thomas96664 years ago
did you just google 'laser project' and think this one was the easiest?
I did that then made something better cause they would catch me out....
