Long range spybug. by cliffyd
I am going to show you a step-by-step process to building a spybug from common electrical componenets.
Step 1: Components
Components list
Part
  1. C1  1n disk capacitor (102) 1 pc.
  2. C2  5.6pF disk capacitor(562) 1 pc.
  3. C3, C4 10 uF Elec. Capacitor(25-50v) 2 pcs.
  4. C5 3-18 Trimmer Capacitor 1 pc.
  5. R1 330 ohm 1/8 w  Resistor 1 pc.
  6. R2, R5, R6 4.7k 1/8 w Resistor 3 pc.
  7. R3 10k 1/8 w Resistor 1 pc.
  8. R4 100k 1/8w Resistor 1 pc.
  9. Q1, Q2 2N2222 NPN Transistor 2 pcs.
  10. L1, L2 5-6 turns copper coil 2 pcs.
  11. 10mm Electret microphone 1 pc.
  12. 9v battery and clip
     All Resistors can be substituted with 1/4 watt. The transistor can be substituted with a 2n3904-06 transistor.
matstermind says: Jun 6, 2010. 1:57 PM
it says "5-6 turns of .5 dia wire" what measurement is .5?
kd8ikt says: Nov 17, 2011. 11:54 PM
gauge/thickness/diameter
matstermind says: Nov 18, 2011. 4:16 AM
i meant is it in milimeters, or other type of measurement
kd8ikt says: Nov 18, 2011. 5:49 AM
i think im on the wrong page/thread http://www.instructables.com/id/Making-a-simple-spybug/
kd8ikt says: Nov 18, 2011. 5:27 AM
(removed by author or community request)
bigfun says: Jan 13, 2011. 3:48 PM
i have no idea what frequency this broadcasts at. is this just supposed to be obvious? i'm going to assume 100 MHz until you say something else. Hmm, that doesn't work. there are a lot of frequencies out there...
cliffyd (author) says: Jul 6, 2011. 5:02 AM
No sorry try around 88-94mhz
nutsandbolts_64 says: Jun 6, 2010. 6:37 AM
wow, now I can do surveillance on beehard44 (lol, pun intended)
beehard44 says: Sep 3, 2010. 2:00 AM
this is supposed to be our communications in sierra charlie hotel *CENSORED CENSORED* lima, riiight?
nutsandbolts_64 says: Sep 3, 2010. 6:49 PM
uuh, roger that hotel-bravo-four-four. you forgot to mention we needed 2 coils, or did you make another version?over. (all pun intended)
cliffyd (author) says: Dec 15, 2010. 4:17 AM
uhhhh # 10 says 2 coils, is that what you mean?
nutsandbolts_64 says: Dec 18, 2010. 2:06 AM
Oh, I didn't see that there.... Now, all I have to do is get that other ceramic capacitor that messed up my circuit and put it where it belongs... then solder.... I should have breadboarded it before I began soldering. Thanks for the correction.
Rendydevara says: Jun 6, 2010. 5:27 PM
how far is ? (the range)
100 meters
aviksaras says: Aug 3, 2010. 3:48 AM
what's mit
aviksaras says: Aug 3, 2010. 3:47 AM
what number is the PCB
Barramundi says: Jun 16, 2010. 3:58 AM
could you post a pdf of the pcb artwork
matstermind says: Jun 6, 2010. 2:29 PM
one more thing, for the 5.6 cap, 5.6 what? pf,uf,...? can you give me a link to the one you bought? thanks
Rendydevara says: Jun 6, 2010. 5:24 PM
is this help ? http://electronics-diy.com/calculators.php
matstermind says: Jun 7, 2010. 5:41 AM
not really, thanks anyway
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
