LongBoarding Paddle
Published
Introduction: LongBoarding Paddle
About: Thanks for Viewing
Theses stand up paddle board paddles are pretty cool. They are made for longboards for controls and for pushing off for speed. They are pretty easy to make and cheap to make also compared to the store bought ones. The tennis ball grips the road to steer or push off.
You'll need some of these
Step 1: Tools and Supplies:
Tools:
jig saw- to cut wood length or find the size
sissors- to cut tennis ball
drill-
phillp bit- for screwing in tennis ball
sand paper
Supplies:
inch diameter wood 8 feet long
tennis ball
electrical tape
screw
Step 2: Making:
Making the longboard stand up paddle board is pretty straight forward. I cut my one inch circular piece of wood to about 8 feet, you can make this length what ever you want to fits you best. I sanded down the wood to make it smooth when using. I then attached a tennis ball to one end. I did this by cutting an X in the tennis ball and putting the end of the wood in the tennis ball. I used screws to surcure the tennis ball. I also added electrical tape for gripping and looks.
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    good idea to push the cut bits of the tennis ball inside, then screw through two layers. I left the flaps outside, and the ball has been moving around too much on my stick. Thanks :-)
