Introduction: Longboard Camera Mount
If you want to take videos when longboarding this instructable is for you. This camera mount is removeable and wont make and permanant changes to your longboard.
Step 1: Materials
All you need:
1/4 bolt
1/4 nut
Peice of wood (i used 3/4")
Step 2: Marking
Mark you peice of wood. the center and where the bolts for the trucks go through. The size of wood doesnt matter as long as its not to small or too big i just used i peice that i found laying around but if you want to use the same size it was 2.5" by 3.5".
Step 3: Drill
Easiest step just drill the holes you marked . the center hole should be 1/4" and the four outside holes should be 3/16"
Step 4: Insert Bolts
As simple as the title just put the bolts through the holes you drilled. Then put the nut on the center bolt to hold it in place
Step 5: Finishing
Drop the camera mount throught the holes on the board, put the trucks on and your done. Now you have a camera mount for your longboard.
