This instructable has been removed by the author.
178
comments
Add Comment
| 1-50 of 178 | next » |
Dec 12, 2010. 3:46 PMisaac!
says:
If you want to buy a longboard or any accessories, subscribing to Originalskateboards on youtube will get you a $5 giftcard for their website
May 27, 2010. 9:24 PMquesoman
says:
i was thinking of using 2 plies of this wood to make a nice carving board. what is your opinion on the wood?
www.homedepot.com/Lumber-and-Composites-Plywood-Sheathing-Subfloor/h_d1/N-5yc1vZ1xgtZbqm7/R-100010255/h_d2/ProductDisplay
Oct 13, 2010. 2:23 PMwazupdoc
says:
i would use maple its hard and sturdy just the kind u need i would use thin sheets of them and glue them with wood glue this is the type they use for most of the boards the best company's use like landyachtz which makes the best downhill/freestyle boards
Jun 1, 2010. 4:51 PMPatented
says:
I have a question for you, what is the difference when shape of the board change? like on these two pictures
Oct 13, 2010. 2:19 PMwazupdoc
says:
i have been longboarding for a long time the first is a sector 9 sandwege and the second is also sector 9 the difference is that the one on the right is a shorter board so if u want freestyle thats cool the one on the left is longer and its more of a downhill deck even though it comes with side winder trucks personalty if your thinking of buying one i wouldn't get a sector nine unless your new to longboarding bc sector nine is okay but i would suggest getting a landyathz bc they make the best longbooards i currently have the switch by them and i have grizzly trucks and in heat orangatange wheels i would suggest this board or any of their downhill/freestyle boards, dont make the mistake of getting a bamboo deck i think they flex to much and u cant do anything on them ,goodluck!
Dec 12, 2010. 3:44 PMisaac!
says:
yes it matters. Ive been longboarding for about 2 years. a few basic guidelines: The lower to the ground, the more stable the board is. in order to aceive this, some boards are bent down, like the Evo, or some have drop through trucks like the Landyachtz Drop Hammer. also, stability is better when the feet are locked into the board. this is called a foot pocket. a good foot pocket is created when the nose is curled up slightly. your feet feel very snug on a board like this like the landyachtz carbon Mummy. When the board is to be used for carving, wheel bite is a dangerous possibility, so often the board above the wheels is narrower so that the wheels can't contact the board, like the Loaded dervish. For dancing, a longer board is better because you have more room: see the Loaded Dancer. One other thing is that for commuter and cruise boards, a kicktail is useful for going off curbs. other than that, generally board shape is a matter of personal style. Professionally made boards are engineered for these purposes, with great results. However, a homemade board is less likely to be used in high performance situations, so whatever style you want is fine.
Mar 18, 2010. 5:19 AMpaperclip32
says:
I'm pretty new to this whole boarding thing,and I don't really like skateboarding,would you think longboarding is easier?I would only be using it for commuting,so no need for special boards.I'm looking at Bustin Board's spliff(?) since they ship here.
Any advise would be appreciated.
Mar 18, 2010. 10:21 AMTeacherOfTheWays (author)
says:
I would not necessarily say long boarding is easier, as it is very different. But if your just looking for commuting a longboard would be much better. Bustin boards are a great company, they would be great for what your interested in.
Mar 18, 2010. 11:21 AMpaperclip32
says:
I just don't like the stiffness of the skateboard.
Also,how does this setup sound?
Bustin Spliff
Seismic extra light trucks
Bones Reds bearings.
Abec 11 Grippins 70mm.
Bustin Spliff
Mar 18, 2010. 12:10 PMTeacherOfTheWays (author)
says:
I would go with different trucks than siesmics, like randals.
Mar 18, 2010. 1:05 PMpaperclip32
says:
any reason?they put that it was the "best combo" or something like thatl
Mar 18, 2010. 6:44 PMTeacherOfTheWays (author)
says:
They will be the best in the long run, they are more versatile.
Mar 19, 2010. 6:37 AMpaperclip32
says:
do you mind helping me choose?i don't want to spend so much and make a wrong choice.
All the trucks for the spliff are here
www.bustinboards.com/SearchResults.asp
May 27, 2010. 8:27 PMquesoman
says:
Get the gullwing ones in the top left corner. those will be the best for your money since they are only 40 dollars
May 27, 2010. 10:52 PMpaperclip32
says:
That was a long time ago,and I got the paris trucks.They're great.Thanks anyway.
May 18, 2010. 5:40 AMmacneal
says:
the higher the deromiter the easier to slide, also you can use simple physics, bigger the contact patch, the more friction
Aug 11, 2008. 3:37 PMzapconquest
says:
What are the best kind of wheels for sliding (what size too)? Also, I noticed in the sliding videos those were skateboards, not longboards.
Apr 12, 2010. 4:45 PMsammchugh
says:
If you're riding a more traditional longboard shape I suggest using 63mm 95a durometer Tunnel Rocks. They wear pretty well and they have a huge contact surface which is nice for a big board, and besides they're pretty classic.
Oct 14, 2008. 12:01 AMcorkey123
says:
rainskates are the sliding wheels to get, specifically designed to slide, killer bees are the most popular of the rainskates line
Aug 11, 2008. 5:32 PMTeacherOfTheWays (author)
says:
in the sliding videos they were longboards not skateboards. But the sliding longboards are slightly bigger but do also have 2 kicktails. But they are different than skateboards. Wheel wise, i am not a very good slider and i dont really know what wheels would be best.
Mar 14, 2010. 5:59 PMPatented
says:
so basicaly, could you just put long board trucks and wheel on a normal board and it will go at the same speed?
Mar 14, 2010. 10:16 PMTeacherOfTheWays (author)
says:
No you could not. Longboards are made specifically for downhill, well some are. Trying to go fast on a skateboard would get you hurt, even if you had longboard trucks on it.
Feb 17, 2010. 1:18 PMyou
says:
"CAUTION: do not buy cheap boards off ebay if they are of the brand Krown or Moose lognboards."
there are actually a few decent moose boards on ebay now if your a new longboarder and dont want to spend to much money
cgi.ebay.com/Moose-DROP-THROUGH-Longboard-With-RANDALL-KRYTPONICS_W0QQitemZ360227655501QQcmdZViewItemQQptZLH_DefaultDomain_0
Dec 30, 2009. 5:42 PMhossynossy5
says:
just a small correction: loaded does have a downhill board, the vanguard started as a downhill board, but it's mostly used for sliding, carving and general freestyle.
Nov 29, 2009. 9:35 PMitsthatsguy
says:
Very Nice Guide, But, i feel like its missing a key element, Carving! sure carving on a longboard is one of the most obvious things you do, but extreme carving (like i do) is won of the best types of longboarding
Nov 23, 2009. 8:12 PMquesoman
says:
What is ur opinion of this board. i noticed it is the same length as the dancer. what do u think of it?? the link is below.
http://www.daddiesboardshop.com/gravity-boards-55-ed-economy-longboard-skateboard-deck.aspx
Nov 23, 2009. 9:17 PMTeacherOfTheWays (author)
says:
Never tried it so i dont know, looks like it might be fun with some randals or paris trucks on there, the stock ones look like they will feel ugly. Probably get some soft wheels for dancing too. Looks like a nice deck though.
Basically you get what you pay for.
Nov 16, 2009. 6:26 PMZaphod Beeblebrox
says:
where could someone buy/how would someone build their own ramp like in the slalom video?
Nov 16, 2009. 9:16 PMTeacherOfTheWays (author)
says:
You would probably have to make your own out of wood.
Jul 25, 2009. 12:14 PMquesoman
says:
i finished my homemade so ill post a slideshow soon. its nice for cruising but not really that good for dancing. i want to get a good dancing board but also one that is good for commuting. i was looking at the loaded dervish but that is at the very top of my budget(considering im only a teenager) and plus idk if my parents will let me get another board. they are pretty strict about having 2 things that do bacically the same thing..... well then y does my dad have like 3 different power drills?????*sarcasm* anyway, do you have any suggestions for a coulpe boards that i could check out that are good for both dancing and commuting but that are not over 300 dollars? 200 dollars would be better though. so if you have any suggestions that would be great.
thanks
quesoman
thanks
quesoman
Jul 25, 2009. 1:11 PMTeacherOfTheWays (author)
says:
Some good dancing an commuting boards?
Let me think.
Something like this is great for commuting and also has some room for dancing and its super fun i used to have one.
http://cgi.ebay.com/Bamboo-flex-longboard-longboards-downhil-setup-carving_W0QQitemZ200366638957QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea6c8476d&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1205|293%3A1|294%3A50
Let me think.
Jul 25, 2009. 9:12 PMquesoman
says:
sounds good ill check it out. i also found a loaded dervish on daddies board shop for 245 dollars. my dad said that we would look into it but my mom was totally uniterested. i dont think they view longboarding as a "legit" sport.
Jul 25, 2009. 10:39 PMTeacherOfTheWays (author)
says:
Cool. Ya the dervish is so sick. You should definitely get it.
And daddies has it for an awesome price.
AND WHAT? Tell them It does not get any more legit than going down a hill at 60mph haha
(Maybe on second thought don't tell them that)
Nov 13, 2009. 5:45 PMZaphod Beeblebrox
says:
aw man i wanted to buy it fro u.... list of boards you currently have?
Nov 13, 2009. 7:04 PMTeacherOfTheWays (author)
says:
Look what i found on eBay, you might want to check it out.
cgi.ebay.com/Loaded-Vanguard-Longboard-paris-trucks-bamboo-Flex-4_W0QQitemZ220504318254QQcmdZViewItemQQptZLH_DefaultDomain_0
Nov 13, 2009. 6:48 PMTeacherOfTheWays (author)
says:
Homemade ceviche, FSM, 09 Hellcat, LBL Komodo
