Longer-Lasting Matches
Introduction: Longer-Lasting Matches
This instructable will show you how to make matches that burn with a slightly smaller flame but will last 5 times as long.
Step 1: You Will Need
You will need:
-Oil (used oil will do as long as its clean).
-Shallow dish
Step 2: Pour a Small Amount of Oil Into the Dish
Firstly, you will need to pour a small amount of oil into the dish. You don't need much unless you are doing loads and oil can be quite expensive.
Step 3: Let the Matches Soak
Let the matches soak overnight. This will ensure they absorb as much of the oil as possible.
Step 4: Let the Matches Dry
Now you will need to let the matches dry otherwise they will not work as well. A good time to let them dry is overnight.
Step 5: The Final Product
The matches should now be dry and ready to use. They will have a slight yellowish tint this is the oil.
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    Cool! TYSM for sharing!
    Do you put also the matches heads into the oil? And they really ignite as easy as before after drying? That would be cool, because the oil should also make them somehow waterproof, I think. I will definitely give this a try!!!
    I put all of the match into the oil and it ignites after drying alot better than wet.
    Why does the oil make the matches burn longer?
    I'm not really sure but it does work.
    I think its because it uses the oil as fuel instead of the word
