3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Look Script For Cutouts
Step 1Add Script
Right click on your cut out and choose edit from the pie menu.
Go to the contents tab in the edit menu and click on "New Script."
Open the new script and replace its contents with the following code:
Open the cut-out contents from the edit menu and click on the add script button.
Open the new script.
Paste the following code into the window, replacing the current contents:
//Simple Rotation Script to give your Bartender a little life
//If this script is set to run, it will turn to face the nearest agent.
//Modify to fit your bartender.
//Based off of scripts by Ope Rand & Christopher Omega
// AXIS_* constants, represent the unit vector 1 unit on the specified axis.
vector AXIS_UP = <0,0,1>;
vector AXIS_LEFT = <0,1,0>;
vector AXIS_FWD = <1,0,0>;
rotation getRotToPointAxisAt(vector axis, vector target) {
return llGetRot() * llRotBetween(axis * llGetRot(), target - llGetPos());
// Strength and damping are values used to control how llRotLookAt and llLookAt move, these values are tunable.
float strength = 1.0;
float damping = 0.250;
default {
state_entry() {
//Stops it from tipping over
llSetStatus(STATUS_ROTATE_X, FALSE);
llSetStatus(STATUS_ROTATE_Y, FALSE);
llSetStatus(STATUS_ROTATE_Z, TRUE);
//llSensorRepeat(string name, key id, integer type, float range, float arc, float rate)
llSensorRepeat("",NULL_KEY,AGENT,10,PI,1); //set the last three variables lower/higher to lessen lag
sensor(integer num_detected) {
vector target = llDetectedPos(0);
// This line points the fwd (X) axis at the target:
llRotLookAt(getRotToPointAxisAt(AXIS_FWD, target), strength, damping);
// This line points the left (Y) axis at the target:
// llRotLookAt(getRotToPointAxisAt(AXIS_LEFT, target), strength, damping);
// This points the up (Z) axis at the target:
// llRotLookAt(getRotToPointAxisAt(AXIS_UP, target), strength, damping);
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Aster
