Step 3Tweak if Necesary
Set the ruler mode to local while selecting your cut out. See which directions it's axes are pointed. By default the script points the positive x-axis at you. You may need to uncomment a portion of the code (a line begining with llRotLookAt) by removing the double slashes infront of a line and comment out another portion of the code (all other llRotLookAt lines) by adding double slashes. You might also have to change the true/false values to allow the cut-out to turn.
Also you can change the sensor values to reduce lag.
Add Comment
