Loom
3,456
31
Published
Introduction: Loom
To make a loom first need to make a frame. The loom is a machine for weaving, built with wood or metal, and can be local or industrial.
Step 1: Measures
Performs measures 30 cm long, 5 cm wide and 1cm thick at a long wooden table. Performs measures 20 cm long, 5 cm wide and 1cm in another separate table.
Step 2: Cut
Cut to the measures each table. These will help us to be able to make the body frame make sure straight cutting and sanding the edges of the wood, for this uses a straight surface, and a sandpaper.
Step 3: Nails and a Hammer.
Wood of the loom with nails and a hammer. This will allow to keep kingdom and do not separate
Step 4: Pin the Nails
Measured and placed to each 1cm of distance a nail. We pin the nails in the edges of the loom because they are needed when we have to start to weave in it
Step 5: Sew
Tie the end of the wool in one of the last nails, pass the wool behind each nail making a zig-zag. Tie the other end into the last nail that is once again made the zig-zag separating a wool up a wool down, I introduce a wooden pallet. Once finished tie the end of another color of wool in the last twine of wool and unstirred within the area where is located the palette.
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    2 Comments
