loading
Step 2: Casting On
First make two loops at the end of the yarn with the left side of the loop on top, like the picture below. Then pull the right loop through the bottom of the left loop and put it on the hook on the side of the loom, and pull the the tail until it is tight on the peg. Wrap the long end in a clock-wise circle on the peg to the right of the one on the side like in the picture. Wrap around each peg once going clock-wise around the loom. Now wrap around each peg a second time, excluding the peg on the side. Wrap the yarn around the side peg a few times when you are done so the yarn doesn't unwind. Now pull the bottom loop over the top loop and off the peg. Repeat with every peg except the side peg going around the loom in a clock-wise circle. Congratulations you have just cast on!
<p>i dont really understand</p>
<p>I learned to knit following an excellent guide I found <a href="http://easy-knitting.weebly.com" rel="nofollow">HERE</a>.</p>
Is this akin to spool knitting? <br>Just out of curiosity. I've done spool knitting before, but never loom knitting. :3
Yes and no. Yes because the process is basically the same. No because the different sizes and shapes of looms create a much wider array of projects that can be completed (chain vs socks, hats, scarves, sweaters, afghans, pot holders, you name it.)
In a way you are right. I had a spool knitter when I was young with four nails on it. The best ones have four pegs or wire loops for easier access lifting the yarn and then pulling the tail down into the hole. I am making a spool knitter at the bottom of my P knitter for making hat cords or for making projects. I loved it as it was the first knitting I ever did.
Yes it is! I love both! :) But in loom kniting you usually use thicker material like yarm, and in spool knitting thinner material.
Love this!!! I loom knit, and have heard needle knitting hurts your hands! You can even do an amigurumi-esqe things with looms,too!! It Is VERY fun for small children too! Instead of the hook they provide, a latch hook works better and faster in my opinion .
Thank you!!! :) I actually never use hooks, i use my fingers.
Its also good if you loop it too tight
I love loom knitting too.. Recently I made a loom out of the letter D and added removable pins so I could work with sock weight wool. Please take a look if you could. Your instruction was very well done.
If you work the yarn towards the inside the tube will go down thru the ring and you wont have so much trouble with the anchor pin catching on your work AND It's easier to see your work that way. Use a Crochet hook with skinnier yarn so it is easier to work.
I've tried that before, and your right it does!
poor kitty
What a wonderful, beautiful and patient cat!
Ha ha thanks!
About This Instructable
532,658views
241favorites
License:
Bio: I love to knit, sew, work with clay and do just about any craft. I love craft instructables and contests: voting, and entering! I have ... More »
More by Lettucehead:How To Loom Knit Make a Funky Safety Pin Bracelet Make A Cute And Handy Pencil Bag
Add instructable to:
