3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Loosening Stubborn Wood Screws with Heat
An old boatbuilder's trick for loosening wood screws.
Step 1Supplies!
Supplies!
You will need:
A stuck wood screw - in this case a smallish, thinnish, bronze slotted flathead screw.
A length of steel rod matching the size of the screw head - I used a 20d nail.
A propane torch.
Vise-grips - 'cause your gonna make that nail HOT.
A screwdriver that fits the screw well.
17 comments
Feb 21, 2011. 9:24 PMerrtyta says:
Ref: Using a soldering iron to get a bugger-stuck wood screw out. Thanks, it worked for me! Although you said you used it on plastic situations: I got a leg screw (2-1/2" flat head) out of a chair...odd angle to boot - It wasn't easy and it took 3-4 tries and I had already lost about 1/2 of the slot from my first attempts without heat tries. Now two more....ah...manana, it's time for cherry pie.
I think if you leave that soldering head on the head until you start to smell the wood/glue heat-up may be the trick. First two times were probably too short -
Last time I held it there for about three mins. Also likely that there was a
cumulative effect.
Oct 25, 2010. 7:16 AMfixings says:
@chuckr44: This method should work for torx screws too.
Feb 16, 2009. 10:11 PMHombre3000 says:
Would this work for plastic?
Feb 14, 2009. 5:48 PMMetalcaster14 says:
thats an interesting torch head
Jul 14, 2007. 3:10 PMbleachworthy says:
yeah, this not only loosens the wood fiber, and breaks glue bonds, but it also expands the screw, making it more difficult to extract. this DOES work, but my favorite method, is to take a can of air, flip it upside down, and spray the screw with the freezing cold liquid ((difluorothene I think) be sure none of the liquid touches water, it will make hydrofluoric acid, and will eat the flesh off your bones.) this shrinks the screw a bit, allowing it to be loosened easily. I'm going to try a combonation of these methods, to see if they work well together. (first heat, then freeze.)
Jan 7, 2007. 4:20 PMnobody says:
I've been doing that for a long time, but with plastics. Instead of heating up a metal rod with a torch, I use my soldering iron.
Feb 12, 2007. 3:18 PMlemonie says:
Please note that this specifically references wood-screws. Wood is a different material, the effect of heat is differeent. And you need much more heat too. However, I too have used the soldering-iron on plastic, it works - you could post an instructable?
Feb 11, 2007. 4:09 PMlemonie says:
This is generally applicable. I spent quite some time roasting an iron gate post peg with a blow-lamp, to get it out (succesfully). Although whacking with a hammer is a good first option.
Jan 19, 2007. 3:26 PMchuckr44 says:
Does this work with tiny torx screws found in hard drive cases? I broke my only tiny torx bit trying to get one of those buggers out, and using TiN bits took forever to drill them out. And my screw extractor didn't work because it could not get a grip in the screw. Perhaps these screws were hardened.
Jan 30, 2007. 8:17 AMVendigroth says:
drill them out, just get the right size drill bit and take the head off. but no if you want to keep the hard drive. also, be careful when you're doing it, i slipped on the last screw, (i was trying to get the round thingy out) cracked my expensive bit in half and gouged a huge hole in the disc.
Jan 7, 2007. 2:55 AMOorspronklikheid says:
Yeah it will probably come out easier if its cold because the screw will shrink a bit when cooled
Jan 7, 2007. 1:41 AMjcpoczatek says:
Old tips are good tips. Is that a geodesic airolite boat?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:Captain Pedantic
