Lose Monitor Cable Quick Fix.
735
Posted in CraftDuct-tape
Introduction: Lose Monitor Cable Quick Fix.
About: Short Produtions Director, Blacksmith,PC Hardware professional, Otaku and Headbanger. I was Searching for Tesla coils when i bumped on this site, sice then, i search for everything here, from Recipes and Br...
There was a cable at my work the kept falling or getting bad contact with a little touch, as i work With CAD it turns to be a pain! so i came with this Quick fix to prevent it from falling. It's really dirt cheap as you will use just one thing.
So let's start!
Step 1: Materials
To do this you will need
1. The lose cable
2. Teflon Tape
Really dirt cheap as you see!
Step 2: Fixing
Warp some teflon type around the cable plug, mine took about 10 turns, after that plug it again and see if it's fitting tight, if not try warping a bit more tape and test again until you got a tight fit.
Step 3: Done!
After a good fit turn on you monitor to find out that it's not getting bad contacts anymore! if you the issue continue even with a tight fit you might have blocked the contacts or your cable is broken inside and you will need to buy a new one :sad:
this can be used on a variety of lose connections around.
    • Flowers Challenge
      Flowers Challenge
    • Spotless Contest
      Spotless Contest
