Sorry on the delay- I suspect it was a 14 tooth hacksaw, but honestly, most any would work- the aluminum is exceedingly soft compared to most any other metal.
This is a version of, "lost wax casting", where the wax is heated to empty the mould before casting.
Sometimes frozen mercury is used, allowed to melt and poured out for reuse.
Sometimes flowers or insects are used.
The idea is to produce a mould for each casting. Foam is just another medium. It could be set in a latex shape then covered with plaster and dissolved with a petroleum solvent to leave the empty mould.
It produces very intricate with low dimensional tolerances, it is used to make items like jet turbine blades at very low cost.
You'll need a furnace for Aluminum since the melting point is much higher than a fire pit will provide. If you watch the video, he explains that you don't need the dry wall paint, but without it you'll have a sandy texture.
i agree with you tinstructable...however i think he should use lead...it has a low melting point. i used to make lead fishing weights with a spoon, pliars and a fireplace.
actually, you can melt aluminum with a fire pit. it just wastes a lot of fuel, and you need to tend it a lot to make sure the pot is in a good hot spot. a fire pit can get to about 2k f if you blow on it. you can even melt iron with just wood and a good blower! it takes a TON of work.
Very nice! I have been wanting to make geek-themed brass belt buckles for quite some time. It seems like this method would work, but I am slightly bothered by the idea of continually having to make patterns. (I guess I could try making my own CNC mill and do it that way.)
Thanks- if you're really interested in casting- greensand molding with a pattern works wonderfully- just requires a little more on the front end and forces you to consider draft angles.
If you're not familiar- draft refers to the fact that green sand cast objects must have a slight taper to them to accommodate removal of the pattern. I.e. a pattern with a 90 degree edge fouls the impression it makes when removed. You add a slight taper (5-10 degrees- the more the easier) and it can release more easily. I've had kids make buckles before- both on CNC in foam, and in foam by hand- That's a great project!
is there any limit to how big the foam sculpture can be? I was thinking using this technique for something about the size of a football,, would that still work?
Sorry on the delay- Limit-wise, it would depend on your crucible. Usually our castings are no larger than about "baseball sized" for volume.
When you get too big, I think you could have some shrinking issues. Typically students get their best finish on the bottom side with most of the shrinkage occuring on the top side of the casting. If you really want a great finish- drywall works great- or you can use paper (glued on with rubber cement) to ensure a smooth finish.
I've thought about that. It would depend on how much heat the aluminum would hold and how hot you got it. Steak brands- throw them on the grill?
I'd considered suggesting it to students- however, I'm afraid I'd have a kid lift up his shirt after the week end and say "Dude- check out what I made in class!" Somehow this seems inevitable- so brands have been delayed.
Heh-heh-heh. I hadn't thought of that but I could see students diong their own version of a Jackass stunt with a branding iron. Yeah, you'd probably have to confiscate the branding irons after they were finished.
Yeah, I think this could work as a branding iron for wood. Aluminum would certainly hold enough heat to scorch wood without worring about it melting.
Thanks for the note. While we try to keep things on the mold and in the tin cans, that's a good note on casting on concrete. I've never been so unfortunate in the hundreds of castings I've seen- however- reading stories online- it would only take one.
I've heard of folks casting on beds of sand. Any other suggestions? Obviously, you're better off not having any spill!! :)
Nice job on the video. Very instructive! I recently had someone who'd been working with iron try to explain this casting technique to me. Your video makes it very clear. Thanks for sharing!
Bio:I'm a junior high "shop" teacher- aka the "engineering teacher" at South Middle School in Waukee. I love making stuff, learning, playing ultimate frisbee, and flying kites. I live with my 2 boys and...read more »
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Let me know if you need any pointers.
Aluminum football perhaps? What's the project?
Could be very fun.
Keep up the good work!
