1) Un-denting the dust caps
2) Re-foaming the woofer
3) Repairing paper cones
In order to complete these steps we need the following materials:
-sewing needle or safety pin
-speaker re-foam kit that fits the woofer in question (I got mine from SpeakerWorks.com http://www.speakerworks.com/foam_surround_sizing_s/63.htm)
-coffee filters
-source of cotton fibers (cotton swabs, cotton balls, yarn, or whatever you have)
Remove these ads by
Signing UpStep 1: Un-denting the dust caps
This is where the sewing needle or safety pin comes in handy. Poke the tip of the needle or pin into the dent in the cone, and position the needle sideways so as to allow one to pry/pull the dent out. Using the needle/pin to get inside the cap, one can push out smaller dents and wrinkles.
Alternatively, a vacuum cleaner hose can be carefully placed over the cone, and the vacuum may pull the dents out. This works for larger dust caps.
The dust cap won't look like new, there may still be creases in it and a small pin hole or two, but it will be in much better shape than it was.
Visit Our Store »
Go Pro Today »
Nice that you saved another old speaker from certain death. Good 'ible!
Speakers are easy to fix if you have a source for the new surrounds.
It's more important to have patience than skill to do this.
Thanx...
RikJamez
Thanks for posting the instructable.
Seems unnecessary to pierce the cap with a pin.
For the tweeter, they are touchy, remember it vibrates at up to 20,000 cycles per second, if you add the weight of the coffee filter and glue to one side it will affect the sound to some degree. It is up to you if you can hear this or if this bothers you or not. If you look around you might be able to replace the tweeter with a new exact replacement one quite economically.
Also while the woofer is out of the speaker you might want to look inside the cabinet and clean the contacts on any crossover controls and consider replacing any electrolytic capacitors in the the crossover. It may or may not have any. If the speaker is old enough for the foam to rot, it could be old enough for the electrolytic capacitors to go bad too.
Now i can fix my old speakers (never had the guts to throw them away ;o).
I was thinking CPR, but this works too.
great instructable
