Low Cost Computer Desk
 by Sobaka-Gemini
Featured
Over the summer I decided I needed a new desk. After looking online at many different desks costing hundreds dollars I figured I could make one for much less. In fact the total cost I estimate to be around $50. This price could go up very quick if you have to buy some power tools or end up going to the hospital because you misuse the tools. On that note I thought I should add in here that I am not responsible for the structural integrity of the desk design nor your proper or improper use of the tools needed. Any way I hope you enjoy this instructable.
Step 1: Materials and Tools
Materials
-Two 2x4' MDF sheets ~$11(each)
-Two 20 hole steel tie plates ~1(each)
-One Quart of paint ~$8
-Six legs~$3.50(each)
-Box of 3/4in Screws~$6
-Polyurethane(Optional, Helps protect against water)
-Test bottle of accent paint (Optional)
-Tape(Optional)
Tools
-Drill/Driver
-Router
-Round over router bit
-Jig Saw
-Coffee tube Cap
-1/8in drill bit
-Sand Paper
-Brush
-Jig saw
-Power Sander
mckooter says: Sep 21, 2012. 5:19 PM
Just wanted to say thanks for this, built my desk over the past few weeks, made a it a bit larger, 8'x10', used a total of 7 of the ikea legs.
So far its great, color is flat paint with satin polycrylic so its a bit less glossy than yours but the idea is still the same...
hopefully the 5 pictures I uploaded will post as well
400863_464718576892176_785712964_n.jpgIMG_20120914_212331.jpg548207_468937509803616_1417815467_n.jpg253525_468937489803618_782578503_n.jpgoffice.jpg
Sobaka-Gemini (author) in reply to mckooterJan 29, 2013. 2:51 PM
Looks great, thanks for the pictures, and great solution for holding up the back.
As a side note; The desk is now about two years old and still working great, the MDF has stayed flat even with the weight of books and a monitor on top, and the paint/finish is still looking like new.
mckooter in reply to mckooterSep 21, 2012. 5:22 PM
also, in case anyone notices that the legs shouldn't hold the desk up, the back is supported by 2x4's screwed into the wall studs. I realized that after ramping up the size so much I might as well secure it to the wall a bit too.
simplifiedbuilding says: Apr 30, 2012. 7:31 PM
This desk is a lot like the one we built with Kee Klamp legs, certainly not as inexpensive as this desk, but the same idea:
http://www.simplifiedbuilding.com/blog/how-to-build-a-custom-ergonomic-computer-desk/
tpullano says: Apr 20, 2012. 6:16 AM
How thick is your MDF? The legs from IKEA mention they are good for a table of thickness at least 1", yet I only see 3/4" MDF's at Lowes or Home Depot. Worried about the screws coming through the top. Is yours 3/4" thick and did you use shorter screws?
Sobaka-Gemini (author) in reply to tpullanoApr 20, 2012. 11:39 AM
Yes, I did use 3/4" MDF which was suitable but a thicker MDF could work fine even with the added weight. Also I did use 3/4" screws but with the plates which added about an 1/8" or so none of my screws went through. I did however use a drill that stops applying force at a certain point (available on most cordless drill/drivers) that allowed me to slowly adjust the torque until I was satisfied without over doing it. In summary as long as you don't go crazy tightening the screws you should be fine. (Also predrill with a small bit and add a drop of wood glue on the threads it really helps)
Sobaka-Gemini
mochimaster says: Apr 18, 2012. 3:37 PM
That looks really useful, and looks store-bought. That's a plus.
Geedox says: Apr 17, 2012. 8:12 AM
Great project for "All-thumbs" like me. Also, in my part of the world it is difficult to obtain specialized parts. As a follow-up, would like some ideas for some sort of shelving storage in the same spirit of this project! Keep it up!
Lthrboots says: Apr 16, 2012. 9:50 AM
Looks great and easy to do. You definitely got my vote on this one.
Sobaka-Gemini (author) in reply to LthrbootsApr 16, 2012. 11:48 AM
Thank you I appreciate it.
Sobaka-Gemini
chaitanya.vedak says: Apr 13, 2012. 3:14 AM
Another Great way would be to First color the Corner is a Base Color of Opposite Contrast. (Like the Green you got) and let it dry
Next use some very narrow Masking Tape (like 3-5mm or so wide)
Then connect the Dots with this tape.
Next Color onto the these lines and the background
Once the paint dries, remove the masking tape to reveal the unpainted stripes
Voila.. Painted Stripes
Sobaka-Gemini (author) in reply to chaitanya.vedakApr 13, 2012. 11:46 AM
Great method, I wish I had thought of that when doing this would have made it much easier.
Thanks,
Sobaka-Gemini
chaitanya.vedak in reply to Sobaka-GeminiApr 15, 2012. 11:45 PM
Your Welcome.. Watch discovery Turbo for many Various method of Painting. Especially Chip Foose, Then there is also West Coast Customs, trick my truck, and American Chopper.. During their builds, they also come to parts where the paint goes on the vehicle, at that time they sometimes explain the procedures too.
Enjoy
astrax says: Apr 14, 2012. 2:21 AM
you have floor mat with my nationality ornament :)
marjorieallea says: Apr 13, 2012. 8:33 AM
Very attractive desk!
chaitanya.vedak says: Apr 13, 2012. 3:16 AM
the Finish is Fabulous.... very Shinny
megainstructa1 says: Apr 12, 2012. 12:12 PM
I like this and it seems relatively easy. You got my vote!
Sobaka-Gemini (author) in reply to megainstructa1Apr 12, 2012. 1:25 PM
Thanks
wthit56 says: Apr 12, 2012. 9:29 AM
I'm fine with hand-drawn plans; quick and easy.
But if you're interested, you could try out Google's free CAD-type program, called "SketchUp". Very easy to use, and very, very free. ;P
http://sketchup.google.com/
Sobaka-Gemini (author) in reply to wthit56Apr 12, 2012. 12:08 PM
Thanks for the advice I will defiantly have to use SketchUp on future projects
Thanks,
Sobaka-Gemini
chrwei says: Apr 12, 2012. 7:16 AM
a tip for getting tape on strait:
- tear off a piece longer than you need so you have room for your fingers at the ends on the sticky sides of the tape, which won't stick well anymore.
- line up one end where you want it, but don't press down hard yet, hold it there light enough that you can turn the tape to line up the other end
- hold the tape taught at an up angle away from the table and line up the other end.
- slowly bring the other end down into place, so that the whole length of tape touches down at once. if you miss, you can pull back up.
- once it's laid down right, press the tape down.
If you have a really long line to make, you can do it in 2-3 foot sections. with some practice you'll learn to do it with the roll so you don't have to tear off sections.
if you tape doesn't end at an edge like it does on this project, you can tear off your finger held sections by pressing down at the spot you want to stay and tearing, use a fingernail to get a good clean edge.
Sobaka-Gemini (author) in reply to chrweiApr 12, 2012. 12:06 PM
Great tip, I personally got a used piece of acrylic and lined the tape up along the edge of the acrylic.
Farrelbark says: Apr 12, 2012. 12:06 PM
I think I'd like to learn how to make that rug you got there as well....
gverble says: Apr 12, 2012. 7:59 AM
I really like this project as well. Can anyone order from IKEA to buy the legs or do I need to be a member?
Sobaka-Gemini (author) in reply to gverbleApr 12, 2012. 12:03 PM
Anyone can, you can also go down to your local IKEA and find the legs in the warehouse.
msmythers says: Apr 12, 2012. 8:13 AM
Table looks nice but I'm glad your math works for cutting because it doesn't work for your estimate of cost. Using your list of only things you priced the total is $59 not $35.
Sobaka-Gemini (author) in reply to msmythersApr 12, 2012. 11:59 AM
Good catch, I have no idea how that happened (monkeys on keyboards) but it is now fixed.
Thanks,
Sobaka-Gemini
The design looks great, man! Nicely done!
legostarwars says: Apr 11, 2012. 7:04 AM
That is a very big desk, you can place there 5-6 computer screens
robertrunyon says: Apr 11, 2012. 5:08 AM
You can get countertop connectors to make joining the pieces easier. You are already familiar with a router so it should be easy enough for you to do.
The site below sells a few different types. But I linked directly to the ones I liked best. They also sell a router template to make it easy to install.
http://www.mcfeelys.com/product/FSC-0020/quotFastCapquot-Flip-Bolt-Countertop-Connecting-Bolts
You can get similar items at local DIY centers, I'm sure.
Great instructable! This might be something I do in the near future.
pfred2 says: Apr 8, 2012. 2:02 PM
I'm at my no budget computer desk, well I call it a stand, now. I needed it to fit exactly in a little cubby hole, so I opted for making it myself. It is crude, but it works surprisingly well. I've since put a clear finish on it, but I've no new pictures of that I'm afraid. Try to imagine it a bit deeper color, with a shine.
robgonzo says: Apr 6, 2012. 6:33 AM
I am planning on building a similar desk in the near future and I've been debating on a laminate top or paint. Given the very nice results you seem to have gotten with paint and polycrylic I think I know what wins! Nice job!
BTW, where did you get those table legs for $3.50 each?
Sobaka-Gemini (author) in reply to robgonzoApr 6, 2012. 8:23 PM
I got the legs at IKEA (They are used for their tables but you can get them separate from the table). Here is a link if you want it I also believe you can get the legs in
many different colors and could make some cool combinations.
http://www.ikea.com/us/en/catalog/products/70217973
Corkas says: Apr 6, 2012. 4:41 AM
great job, thanks for the cool ideas, keep them coming
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
