Introduction: Low Cost Arduino Jammer 433 Mhz
Introduction
In this project I will demonstrate the use of an arduino
as a jammer for the range of 433 Mhz using only 2 element´s
List of
materials:
-Arduino
-433 RF Module
Step 1: Project
For this project I use one breadboard but you can
simple connect the RF transmitter to the arduino, and also you can get the
power from the arduino board, I use 12 Volts.
The arduino will generate one square wave and it will
feed the RF module
I get the spectrum using one RTLSDR at the distance of
2 meters from the antenna
Step 2: Spectrum of the Arduino Jammer
Step 3: The Test
The test
was conducted using as an reference an CAR KEY, The typical spectrum of 433 Mhz
car Key is in figure A, the scale is in
db, the measures were taken using one RTLSDR Pen
Step 4: Where Is Wally ???
After I turn on the arduino and I press the car Key I get the spectrum of figure...
Where is the signal Key..
Step 5: Code
And now the best part .. the source code of arduino ;
void setup()
void loop()
tone(8, 15000); // generate square wave
design by Zerito.com (mail(at)zerito.com)
