3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Low Cost Circuit Board Pre-Heat workstation for Solder Re-work
Circuit board pre-heat workstations are very expensive, $350.00 - $2500.00.
The goal of this instructable is to demonstrate how to make a circuit board pre-heat workstation for around $50.00 with no special tools and the majority of materials from Home Depot and Harbor Freight Tools.
Special Warning - Note This project involves working with AC line voltage and high current.
If you have little experience working with household line current please get someone to help you with this project.
I will try to assist you with areas of caution, but you must be aware that AC current can be very dangerous.
By reading this Instructable you must be aware that I am not responsible for any injury or damage you may cause to yourself or your surroundings. (With the normal warnings out of the way, lets have some fun)
Step 1Bill of Materials
Bill of Materials
Get your pad and pencil we are going shopping:
Some 1/4" and 1/2" plywood from Home Depot or Lowe's)
(Future upgrade, I want to build a metal case for the heat blower and circuit.)
1 $9.99 Heat Gun from Harbor Freight Tools
1 Three prong (grounded ac power cord)
(Special Warning - DO NOT USE THE UNGROUNDED POWER CORD THAT CAME WITH THE HEAT GUN)
1 1 1/2" copper elbow pipe fitting
1/4" square tubing - or whatever size you can get
4 machine screws, nuts and washers
Power cord wire hold down clamp - Electrical department
16 gage wire (assorted colors)
16 gage wire nut and wire terminal.
Special Warning! (You must use at least 16 gage wire for the high current side of the circuit)
Smaller gage wire for fan and low circuit side of the circuit
Roll of steel strap (electrical department, Home Depot)
1 3/4" or 2" hole saw
Electrical Components
Q4015LT Triac/Diac (Mouser, Digi-Key or similar)
Heat Sink (nut and bolt to fasten heat sink)
(I used Digi-Key part number HS107-HD)
Special Warning (YOU MUST USE THE HEAT SINK)
.1 uF Capacitor (Ceramic at least 50V) (Mouser, Digi-Key, Radio Shack)
10K Resistor (at least 1/2 watt)
100K potentiometer (variable resistor) (at least 1/2 watt)
4 wire Terminal connector strip (Mouser, Digi-Key, Radio Shack)
5 wire Terminal strip (Mouser, Digi-Key, Radio Shack)
12V DC Fan 60 cm X 60 cm X 25 cm (Mouser, Digi-Key, Radio Shack)
Knob to fit potentiometer shaft (Mouser, Digi-Key, Radio Shack)
16 comments
Oct 11, 2011. 2:49 PMzmatija says:
Can you upload schematic for regulator, web page is not accesible...please
Feb 8, 2012. 1:07 PMtamagotono says:
You have to love the Internet Archive (A.K.A. the Wayback machine) Here is a link to the website that had the schematics. I have also attached the schematics themselves for future reference.
http://web.archive.org/web/20070105221458/http://home.cogeco.ca/~rpaisley4/x1200WControl.html
Oct 5, 2009. 6:25 PMMACKattacksnipe says:
Very nice
Aug 11, 2009. 7:40 PMChris2048 says:
I can't seem to find a (cheap) source of 5/2" copper elbows. Could I use something else (or bend something else)?
Sep 23, 2008. 4:45 AMpanstar1 says:
I just bought a digital heat gun ,& I would use it b/c I can set the temp exactly. but you should have put a temp gauge to show the temp. the controller you made is basic a light dimmer couldn't you just buy one they are rated for a max of 660 watts ? well we all use what is more convent in our own situation !
Jul 13, 2008. 2:08 PMthermoelectric says:
Very good instructable Nice pics Good explaning I'm rating u 5
Nov 13, 2007. 10:12 PMsnowrobot says:
Thank you. This is a very well done instructable.
Oct 1, 2007. 12:16 AMsensoryhouse says:
hahaHAHAHA! I just bought one of those heat guns from HFT. The first one broke the first time I used it, make sure you save your receipt. Not bad for $10.
Jul 10, 2007. 4:37 AMferalbeagle says:
I found one of these at OSH
Jul 1, 2007. 7:57 AMmrmath says:
The title of this instructable makes it sound like a Doctoral Disertation. Not that it's a bad thing. It just reminds me of sitting at my bachelor's graduation reading the names of the disertations of the doctoral folks.
Jun 30, 2007. 10:49 PMHamO says:
Awesome!! Extremely well done instructable, great pix. Thanks for sharing this idea and construction.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:jpitz31(Joe Pitz Technology Blog)
Software Developer, like to work with electronics, embedded systems, robots etc.
