Step 2Timing Belt Pulley Assemblies
iImage Information
The first thing we did was build the timing belt pulley assemblies. There are a lot of possible ways to do this, but basically, we used a collar-bearing-bracket-pulley-bracket-bearing-collar setup. We made several metal L brackets - just drilled a 1/2" hole in them for the ball bearings to fit in to. Then we saw some electrical conduit boxes at Home Depot and used them to make U shaped bracket. Both approaches are fine. It helps to have some shorter 1/4 rods to test these out - we used 2.5" pieces for ours. The final assembly has one 3', 1/4" rod connecting the two sides to prevent racking.
