3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Low Cost Hobby Servo XY Table
Step 5Clamp the Timing Belts to the Stages
To attach the X stage, we used an aluminum plate (about 1"x3") under the Y stage board with two screws on each side of the timing belt. We drilled two holes in the X stage to get our 3" driver bit in there - put in two screws, then slide the assembly up a bit and add two more screws. For the Y stage, we made two aluminum plates (one about 1"x3", and the other about 1"x1") to connect the belt to the stage. In each case, you are just trying to clamp (or pinch) the belt to the mechanism.
4 comments
Nov 4, 2009. 3:43 AMakirawind says:
if i were going to use roller-chain-sprockets instead of timing belt, is that possible to clamp the chain like what you've done here?
Nov 4, 2009. 4:15 AMakirawind says:
another question here. in this step 5 (picture number 2), does the small wood block, which attach on the Y-axis top glide, glue/screw together with the X-axis ?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
86
Author:CarlS
