3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Low Cost Indoor Pond
I built this pond for my living room in two days. The total cost was less than $200, using common tools and other items available at your local hardware store or home and garden center.
Step 1Initial design
Decide where you will put your pond, and how big you want it to be. I chose to make mine 4' X 4'. The actual frame is 16" tall, but the water is only 8" deep, and raised up 8". One thing to consider is that 1 gallon of water weighs about 8 pounds. Here is a link to a good pond calculator. My pond holds about 70 gallons (560 pounds). If you place your pond on an upper level of your house, you should try to place it along a load bearing wall. A larger pond should be placed on the ground floor. Please make sure your floor will be able to hold your pond. Nobody can be held responsible for any catastrophies but you. Do your homework. This link is a good place to start. FYI, a waterbed holds ALOT more water than this!
44 comments
1-40 of 44next »
Sep 13, 2011. 6:14 PMforrestpaige says:
Thanks for this have been thinking of a indoor pond and yes this idea did come to mind but I did not think of the raised bed or the moisture detectors under the bed. Excellent presentation. Very good advice.
How many fish in your pond and any other problems with the pond or the keeping of your fish. i e the light factor?
Aug 15, 2008. 4:17 PMMakerBreaker says:
to make it all perfect just add some goldfish or koi. but since its indore i prefer goldfish bc koi get big
Jul 7, 2011. 7:00 AMwinterwindarts says:
Goldfish can get just as large as koi...their owners just tend to take less care with them so they usually die before getting so big. I've seen regular goldfish that were nearly two feet long (yes, I'm certain that they weren't koi). Contrary to popular belief, goldfish like all other carp need massive quantities of water that is more heavily filtered than other aquarium fish. A filter rated for three to five times the capacity of the tank would not be too much.
Carp such as koi and goldfish grow continually, releasing growth regulating hormones into the water. Once the hormones get to a certain concentration the fish stop/slow down growing. Unfortunately, by this time they are already larger than the tank can safely sustain (one 1 inch long of fish per gallon, eight gallons per 4 inch long fish, 32 gallons per 8 inch long fish, ect.-larger fish produce more waste and need more water per inch of length than smaller fish).
Interestingly, when my sister was in Japan she saw carp (unknown if they were koi or goldfish/comets) that were six FEET long. The temple pond was continually fed/flushed out by a mountain stream so the growth regulating hormones couldn't even begin to build up. Unfortunately she couldn't get any good pictures.
Apr 11, 2010. 9:24 PMstatic says:
An idoor pond had never occurred to me as something to do. I have been thinking of getting some golfish or the heck of it. Something like this beats a boring fish bowl or tank. Though I think I'd do some shopping for containers constructed to hold water without any additional structure first in mind first. Something like a small livestock watering pan/tank.
Aug 23, 2007. 1:05 PMWileECoyote says:
I'm new here and couldn't find any info on commenting on instructables that are a few months old or older, so I apologize if it's a no-no. I like the idea of the indoor pond. I think it might amuse the cats and dog as long as they don't fall in, any idea if it would be a problem if they drank the water? Also, have you considered tiling or using a faux brick to cover it? I think it would be a great place to use mosaic, making it a little more artsy.
Aug 23, 2007. 1:28 PMWileECoyote says:
Wow, quick reply! Thanks. If I put fish in it I'd probably start out with small, cheap feeder fish to determine if the cats or dog would mess with them and to gauge my fish-keeping skills.
Aug 16, 2009. 7:27 PMcontainer_gardener says:
Good idea. I'd like to try this, but I have a dog who might use the fish as a secret snack.
Mar 30, 2010. 4:09 PMzascecs says:
Haha, quite typical of them, no?
Mar 30, 2010. 2:48 PMgnawlej says:
Feeder goldfish are generally a poor choice for cycling. They are raised rapidly in spartan conditions (and then housed at the LFS in similar). They aren't meant for a long, healthy life; they are bred to end up in the belly of a pet. Furthermore, as a carp, they create a lot of waste, which makes it very difficult to build up a bacteria colony before the ammonia levels kill the fish.
You can do a fishless cycle by tossing a couple frozen shrimp into the pond. As the shrimp decomposes, ammonia is released, providing a food source for the bacteria and starting the nitrogen cycle. Then just start testing the water after about a week or two.
Feb 23, 2010. 6:44 PMHanyouKit89 says:
After i move out of my parents' house, I'm totally looking for something like this to keep my turtle in. Great tutorial.
Mar 30, 2010. 3:16 PMarmourkris says:
I actually did something almost exactly like this for my turtles, except that it's 5'x3'x3' and made entirely from 2x12's
Mar 15, 2010. 1:58 PMjayhawk67 says:
the best part of this instructable was the wife comment-not that the instructable wasn't good
Jul 17, 2009. 7:28 AMKillanat3 says:
Just on the note of the Dry wall what if you put a small rock face water fall feeding in to the pond. Then just adjust the one top piece to accommodate the water fall. or even one of those trendy slate water falls along the wall, or even a piece of textured Plexy class with a edge and some cool LEDs mounted behind it. LOL any was look at me getting all excited. Great Write up! I'm going to have to do this project this summer!
Jul 16, 2009. 8:47 PMbob321 says:
lol that was a funny ending good job by th way
Jun 6, 2009. 10:53 AMDopeman says:
Great DIY project im going to do this over the summer. i was gonna make an outdoor but it would have been costlier and harder to make also there is a cat problem for the fish so this is really helpful thank you.
May 10, 2009. 11:49 AMsmoky305 says:
im going to mack one ill send you a pik wean i do
Aug 5, 2008. 2:37 PMlukeal says:
I was wondering if you had thought of putting a clear cover (glass/plexi) on it and making it into a coffee table or something. I was thinking of something along those like (a zen sand garden under a coffer table) to make something artistic and usefull. This just set me off on the tangent of being able to add water to it. I bet there would be 'condensation issues though...
Jan 1, 2009. 6:53 PMPunkguyta says:
I reckon them fightin words.
Jul 23, 2008. 2:56 PMindigoblu says:
Omg! did you get your ideas from somewhere or did you do it all yourself, I was looking for an indoor fountain to buy (when I came across this)& after flicking through it I'm going to try it - it looks more fun (& more than likely costs less)is there anything else you build?, p.s I like the bit at the end xD
Jul 3, 2008. 6:16 PMarmourkris says:
I did almost the same thing for my turtles, only mine is about 300 gallons when full. i keep it at 120 so as to not drop it through the floor into my neighbors apartment. that would not be easy to explain to the landlords.
Feb 22, 2008. 5:12 PMspylock says:
Good job!
Jan 14, 2008. 8:36 AMAdvocat says:
I want to build a pond in my front room, which have glass walls and a tabletop. The fountain might be nice, but it would have to be small enough for room on the top, like to have food.
Nov 3, 2007. 3:57 PMDELETED_axol123 says:
(removed by author or community request)
May 31, 2007. 4:45 AMSquee says:
I've been thinking about doing an indoor pond project similar to this. Also, I miss Meijer where I live *pouts*
Mar 8, 2007. 8:10 PMHOMEPIE64 says:
awesome 4 1/2 out of 5
May 29, 2006. 1:37 AMPrometheus says:
If you need to regulate water flow, simply make a choke to cut inlet watter supply, mto control a particularly-zeaslous pump motor. Just adjust a venturi to limit flow and then no further adjustment is necessary.
May 15, 2006. 10:10 AMkrusty says:
"I'd like to thank my wife for leaving me, so that I may spend my time doing fun things like this, and enjoying myself fully. :-)" That's the best comment I have ever read!!! LOL I'm sorry, but was her leaving anything to do with building a pond in the middle of your lounge? If I knew it was that easy (to get rid of my wife), I would have built one years ago!! Just a couple of suggestions! If you leave some extra plastic sheeting, you can fold it over the sides and staple it around the outer edge. You could then use some stick-on rubber weather strip around the top edge to stop water leaking out at the top. If you angled the top boards in just very slightly, any over-splash would drain back into the pond. You could also make the outer edge and top lip slightly larger, that will allow it to slip over the main frame, thus allowing it to be removed easily for cleaning and maintenance.
May 28, 2006. 10:30 AM_soapy_ says:
You'd have built a wife? That's just sick, man! ;-)
May 28, 2006. 10:31 AM_soapy_ says:
Hey, the reply didn't stick where it should have! That was for Krusty, obviously.
May 21, 2006. 12:18 PMc0dek says:
I've been looking for a reason to get rid of my cats - this is the perfect excuse!
May 16, 2006. 6:16 PMsaites2001 says:
Very cool project. I think I might try to make one, only smaller. I've got an old fountain motor somewhere . . . and one of those odd misting devices . . .
May 15, 2006. 8:23 PMleevonk says:
I made an indoor garden/pond in my dorm room in college. It had very low walls (4 inches) and sat right on the floor, so people kept stepping on the plants, some of which were cacti. Basically everything died and the pond dried up. The only cool thing was there was an ant colony in this pile of moss that I put in there (took it from the woods) and they would scamper around and I would feed them crumbs from my little debbie snack cakes. My roomate didn't like the ants though.
May 15, 2006. 8:24 PMleevonk says:
oh yeah, people stepped in it because it took up 90% of the room.
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:drum303
