Low-Cost Interactive Whiteboard
5,647
47
4
Posted
Introduction: Low-Cost Interactive Whiteboard
Walk into any primary or secondary school today and chances are that at least one teacher will be using an interactive whiteboard as part of their lesson. In fact, the number of interactive whiteboards used in educational contexts only seems to be increasing, and with good reason, these whiteboards provide greater opportunities for collaboration, increased participation and a better experience for both teachers and students alike.
However, these interactive whiteboards aren’t perfect. For one thing, if these whiteboards are so beneficial then what has prevented some teachers from adopting them? I left secondary school just over a year ago and whilst the school I attended did have a number of interactive whiteboards installed in a few classrooms, these were few and far between. But why? As a student these whiteboards added a new dimension to a regular class by allowing for annotation and collaboration, making the lesson much more engaging overall.
Well one of the major reasons it seems, is cost. Typically, brand new interactive whiteboards range in price from around £400 up to £3000 and thus are a huge financial investment for schools or educating bodies. Often these interactive whiteboards also require specific hardware and software from a single provider, meaning it can take some time to get parts replaced or fixed if needed.
However, upon joining Kainos (a software company headquartered in Belfast) I learned of a project created by one of my colleagues that could help overcome these problems. This project, “Whiteboard”, can provide an alternative solution by providing the same service at a fraction of the cost. Whiteboard, which was initially created by Michael Kemp as part of his final year university project, provides interactive, collaborative services at an affordable cost and is therefore extremely useful to a wide number of sectors and use cases, particularly education. Michael worked with the company’s “Applied Innovation” team to develop a service to allow people to collaborate on projects through a whiteboard functionality and use of real time communication. I was therefore given the chance to test and enhance the operational implementation of this project, meaning I got to try my hand at some DIY (though this isn’t compulsory) and use some great features.
By using this project I discovered that you can create your own interactive whiteboard using off-the-shelf equipment for as little as £7.74, if you already have a computer and an old Nintendo Wii remote lying around, and even these costs could potentially be further reduced. Even if you don’t have these components readily available a Ninentdo Wii remote can purchased for £10 and a Raspberry Pi can be used as a cost effective computer. I’d recommend the Raspberry Pi 3 Model B which can be purchased for £30. If you plan to use the project in front of an audience or classroom then you may also wish to use a projector. Thus this project is widely accessible and inexpensive.
I therefore hope that the Whiteboard project will provide teachers, educators or anyone really with a need to collaborate and communicate with a low-cost yet effective solution. If you feel that this project may be of some use to you it would be great if you could give it a try and provide some feedback on your experiences with the project. So, now that the sales pitch is out of the way, please take a look at the Whiteboard project on Github here: https://github.com/KainosSoftwareLtd/Whiteboard and follow the instructions below to use the project as an interactive whiteboard!
Step 1: Setting Up the Raspberry Pi 3 and Chromium
Equipment Needed
  • Raspberry Pi 3 Starter KitI
  • R Pen (can be purchased or made – if I can make one, anyone can)
  • Wii remote
  • Projector
Whiteboard can run on a variety of devices, including the Raspberry Pi 3. A starter kit for this model can be purchased from Amazon for £42.35 here or just the base Raspberry Pi 3 can be purchased for £30.
The Pi 3 can therefore provide a cost effective platform to run the Whiteboard project and facilitate the features of an interactive whiteboard. Alongside the collaborative whiteboard feature, the project also allows for the streaming of audio and video through a web browser (using what is known as web real-time communication or “webRTC”). I have found that the best browser to support this on Raspberry Pi is Google’s “Chromium.” I have outlined the steps for installing this browser below:
From here you can check if the chromium browser has been installed correctly by navigating to “Menu -> Internet -> Chromium Web Browser”
To test that Chromium is configured successfully and that it is capable of running whiteboard please open a new Chromium browser window and navigate to https://kainoswhiteboard.herokuapp.com. Here you can play around with the initial whiteboard configuration. If, however, you want to set up your own version of Whiteboard, instructions on how to install and run the Whiteboard project locally can be found on the project’s companion site, https://kainoswhiteboard.herokuapp.com. A few steps will need to be altered when loading the project on a Raspberry Pi. I have outlined these below:
NodeJS
To install NodeJS on a Raspberry Pi, open a terminal window and run the following commands:
wget https://nodejs.org/dist/v4.3.2/node-v4.3.2-linux-...
  • Once NodeJS has been installed copy it to the local folder by running the following commands:
  1. wget https://nodejs.org/dist/v4.3.2/node-v4.3.2-linux-...
  2. tar -xvf node-v4.3.2-linux-armv6l.tar.gz
  3. cd node-v4.3.2-linux-armv6l
Once NodeJS has been installed copy it to the local folder by running the following command:
sudo cp -R * /usr/local/
npm
When NodeJS is installed simply run the following command to download and install npm: sudo apt-get install nodejs npm (Note: After this step you may need to run “cd ..” in the open terminal window in order to exit the installed NodeJS folder)
Step 2: Local Installation
From here on, you will need to clone the project and install any dependencies. For this process and the steps needed to run the project locally follow the same instructions shown here: https://kainossoftwareltd.github.io/Whiteboard/localinstallation.html.
By installing the project locally, you ensure that only you (and anyone you provide your computer’s IP address to) can connect to a meeting room session. It also allows you to configure the Whiteboard project so that it suits your needs. Your own configuration can then be hosted online via Heroku for much easier access. Details surrounding all of this can be found on the companion site.
Step 3: Assembling an IR Pen
You can even create your own InfraRed pen in order to further reduce costs. There are plenty of instructions and tutorials online showing how this can be done. Luckily, these instructions are straight-forward enough that even I could make one without too many tears and injuries. I used an old highlighter and some cheap components from a local hardware store to create my masterpiece.
The best instructions I found were those provided at https://www.instructables.com/id/Wiimote-Whiteboar...
Making your own IR pen will also help keep costs down. The costs for my IR pen were:
  • 1 X 3mm IR LED = £0.89
  • 1 X push to make switch = £0.99
  • Wire = £2.99
  • 2 X AA batteries = £0.39
  • Battery Holder = £0.99
  • Highlighter pen = £0.99
  • Insulating tape = £0.50
TOTAL: £7.74
Purchasable Alternatives
If, however DIY isn’t one of your strengths and you’d like to avoid the hassle there are a number of purchasable alternatives available:
Step 4: Installing the Software
Finally, you’ll be glad to know that the last thing you need to install is a piece of software known as “python-whiteboard”. This can be easily installed by following the instructions below:
  1. Open a terminal window and navigate to your home directory
  2. Run git clone git://github.com/pnegre/python-whiteboard.git
The project can then be started by navigating to the newly created python-whiteboard folder (via file explorer) and running/double-clicking “python-whiteboard”.
That’s it for the ground work, now you should be ready to go.
Step 5: Calibrating/Running Whiteboard With an IR Pen
Getting the position for the Wiimote just right can also take some time (and a lot of patience). Again the best instructions I’ve found are listed below:
“For a desktop screen, laptop screen, or a small projected surface, place the Wiimote at a height about as tall as the middle of your screen. Next, the Wiimote should be off center 8″-16″ left or right. I suggest to the left for righties and to the right for lefties. The Wiimote should be about three feet back from the screen for a 20″ screen. It should be further away for larger screens and closer for smaller screens. Also, the Infrared camera end of the Wiimote should be pointed at the center of the screen.”
The next step is to calibrate the Wiimote’s ability to track the IR pen. To do this simply click the calibrate button and follow the instructions on-screen. Your computer will now recognise a mouse click when you press the button on your IR pen.
This means that you can use your IR pen alongside the whiteboard project to replicate a real interactive whiteboard.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
3 Comments
what I imagine about this thing is it can be very useful to explain anything by just hovering 'the pen' over my laptop screen while I am into a presentation without any additional stuff such as touch screen. amazing !!
Professional interactive whiteboards are so expensive, this is a great cost effective option!
